QT Py ESP32-S2 - CircuitPython - OneWire
mwg72
Post by mwg72 »
I'm sure I'm missing something simple here but, I'm trying to get a ds18b20 to work on a QT Py Esp32-S2.
Works as expected on a Feather M0 however, on the QT Py I get no responses back, below are the outputs from my tests on both of the devices.
Any suggestions?
Adafruit CircuitPython 7.1.1 on 2022-01-14; Adafruit Feather M0 Express with samd21g18
import board
from adafruit_onewire.bus import OneWireBus
ob = OneWireBus(board.A0)
ob.scan()
[<OneWireAddress object at 0x20003a50>]
devices = ob.scan()
for device in devices:
print("ROM = {} \tFamily = 0x{:02x}".format([hex(i) for i in device.rom], device.family_code))
ROM = ['0x28', '0x87', '0xbb', '0x3f', '0x46', '0x20', '0x1', '0xe3'] Family = 0x28
Adafruit CircuitPython 7.1.1 on 2022-01-14; Adafruit QT Py ESP32S2 with ESP32S2
import board
ob.scan()
[] <-- Empty return
devices = ob.scan()
Matt
danhalbert
Re: QT Py ESP32-S2 - CircuitPython - OneWire
Post by danhalbert »
Just to check, is it wired as indicated here: https://learn.adafruit.com/using-ds18b2 ... -2979775-1
with a 4.7K pull-up resistor?
mwg72
Post by mwg72 »
Yes it is.
danhalbert
This turns out to be a bug, or at least two bugs. Tracking the problem here: https://github.com/adafruit/circuitpython/issues/5865.
Thanks for encountering this, and for the testing!
