Issues with PCA9685 and Servos (Arduino Uno)
bluegoo
Post by bluegoo »
I am having quite a bit of trouble attempting to use a PCA9685 to control a servo. While my project calls for 28 servos, I am struggling to get even a single servo to sweep.
Hardware:
I am using an Arduino Uno as the microcontroller along with Miuzei SG90 servo motors.
Wiring:
Here is a link to some pictures of my wiring: https://imgur.com/a/0R7JHjg
In case those images are not clear, I have VCC <-> 5v, SCL<->A5, SDA<->A4, GND<->GND. Additionally, I have a 5v5a additional power supply screwed into the terminal block (to power the servos).
Code:
I am using the Adafruit PWM ServoDriverlibrary. URL: http://adafruit.github.io/Adafruit-PWM- ... river.html
I have tried both the "servo" sample example code as well as custom written code, neither of which seem to do the trick.
"servo" Example Code
  This is an example for our Adafruit 16-channel PWM & Servo driver
  Servo test - this will drive 8 servos, one after the other on the
  first 8 pins of the PCA9685
  Pick one up today in the adafruit shop!
  ------> http://www.adafruit.com/products/815
  These drivers use I2C to communicate, 2 pins are required to
  interface.
  products from Adafruit!
#include <Wire.h>
#include <Adafruit_PWMServoDriver.h>
// called this way, it uses the default address 0x40
Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver();
// you can also call it with a different address you want
//Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver(0x41);
// you can also call it with a different address and I2C interface
//Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver(0x40, Wire);
// Depending on your servo make, the pulse width min and max may vary, you
// want these to be as small/large as possible without hitting the hard stop
// for max range. You'll have to tweak them as necessary to match the servos you
// have!
#define SERVOMIN  150 // This is the 'minimum' pulse length count (out of 4096)
#define SERVOMAX  600 // This is the 'maximum' pulse length count (out of 4096)
#define USMIN  600 // This is the rounded 'minimum' microsecond length based on the minimum pulse of 150
#define USMAX  2400 // This is the rounded 'maximum' microsecond length based on the maximum pulse of 600
#define SERVO_FREQ 60 // Analog servos run at ~50 Hz updates
// our servo # counter
uint8_t servonum = 0;
  Serial.begin(9600);
  Serial.println("8 channel Servo test!");
  pwm.begin();
   * In theory the internal oscillator (clock) is 25MHz but it really isn't
   * that precise. You can 'calibrate' this by tweaking this number until
   * you get the PWM update frequency you're expecting!
   * The int.osc. for the PCA9685 chip is a range between about 23-27MHz and
   * is used for calculating things like writeMicroseconds()
   * Analog servos run at ~50 Hz updates, It is importaint to use an
   * oscilloscope in setting the int.osc frequency for the I2C PCA9685 chip.
   * 1) Attach the oscilloscope to one of the PWM signal pins and ground on
   *    the I2C PCA9685 chip you are setting the value for.
   * 2) Adjust setOscillatorFrequency() until the PWM update frequency is the
   *    expected value (50Hz for most ESCs)
   * Setting the value here is specific to each individual I2C PCA9685 chip and
   * affects the calculations for the PWM update frequency.
   * Failure to correctly set the int.osc value will cause unexpected PWM results
  pwm.setOscillatorFrequency(27000000);
  pwm.setPWMFreq(SERVO_FREQ);  // Analog servos run at ~50 Hz updates
  delay(10);
// You can use this function if you'd like to set the pulse length in seconds
// e.g. setServoPulse(0, 0.001) is a ~1 millisecond pulse width. It's not precise!
void setServoPulse(uint8_t n, double pulse) {
  double pulselength;
  pulselength = 1000000;   // 1,000,000 us per second
  pulselength /= SERVO_FREQ;   // Analog servos run at ~60 Hz updates
  Serial.print(pulselength); Serial.println(" us per period");
  pulselength /= 4096;  // 12 bits of resolution
  Serial.print(pulselength); Serial.println(" us per bit");
  pulse *= 1000000;  // convert input seconds to us
  pulse /= pulselength;
  Serial.println(pulse);
  pwm.setPWM(n, 0, pulse);
  // Drive each servo one at a time using setPWM()
  Serial.println(servonum);
  for (uint16_t pulselen = SERVOMIN; pulselen < SERVOMAX; pulselen++) {
    pwm.setPWM(servonum, 0, pulselen);
  delay(500);
  for (uint16_t pulselen = SERVOMAX; pulselen > SERVOMIN; pulselen--) {
  delay(500);
  // Drive each servo one at a time using writeMicroseconds(), it's not precise due to calculation rounding!
  // The writeMicroseconds() function is used to mimic the Arduino Servo library writeMicroseconds() behavior.
  for (uint16_t microsec = USMIN; microsec < USMAX; microsec++) {
    pwm.writeMicroseconds(servonum, microsec);
  delay(500);
  for (uint16_t microsec = USMAX; microsec > USMIN; microsec--) {
  delay(500);
  servonum++;
  if (servonum > 7) servonum = 0; // Testing the first 8 servo channels
Custom Code
#include <Wire.h>
#define FREQUENCY 60
#define SERVOMIN 122
#define SERVOMAX 590
  Serial.begin(9600);
  Serial.println("Moving the damn servo!");
  pwm.begin();
  pwm.setPWMFreq(60);
int angle = 180;
int pulse = map(angle,0,180,SERVOMIN,SERVOMAX);
  pwm.setPWM(0, 0, pulse);
  delay(1000);
Things I've tried:
  • Confirming voltage of both board and servos using multimeter
  • Verified servos work independently (swapped 12 in total)
  • Changed all wires 3x to ensure no faulty connections
  • Swapped Arduino Uno for a spare to ensure it was not the microcontroller
  • Tried 6 total PCA9685 boards (on third set now)
  • Calibrated the SERVOMIN and SERVOMAX to my servo specifications
  • Using a breadboard, wired up a singular LED to try GPIO functionality, which was successful
If anyone has any ideas, please let me know - I am out of troubleshooting options on my end.
Re: Issues with PCA9685 and Servos (Arduino Uno)
I don't see any problems in your wiring and the example code is known to work with our boards. I'd contact the seller of the clone PCA9685 board you are using for assistance.
