AHT20 STEMMA board not recognized
stephenfeagin
Post by stephenfeagin »
I am using a Metro M4 Airlift Lite, and I have both an AHT20 STEMMA board and a DHT20 module. I have no problem running the simple test example with the DHT20, using both CircuitPython and Arduino. But for the AHT20 STEMMA, the code will not run. In CircuitPython, it just tells me that there is no I2C object at address 0x34. In Arduino, it will run but the measurements all come back as 0. I have double and triple checked wiring, and I can't see any reason why the AHT20 wouldn't be recognized. Is it just a dud? Is there something that has to be done notably differently than what the product overview (https://learn.adafruit.com/adafruit-aht20) shows?
dastels
Re: AHT20 STEMMA board not recognized
Post by dastels »
Can you post clear photos of the wiring and connections?
stephenfeagin
I’ve tried both ends of the breakout and two different JSTs. Doing i2c.scan()in circuitpython doesn’t find any I2C addresses.
adafruit2
Post by adafruit2 »
make sure you are powering it from 3v not 5V
stephenfeagin
Very good to know, I hadn't realized it needed 3V. I switched that over but it's still not showing up.
adafruit2
Post by adafruit2 »
ok good! is there something on the sensor board itself, could you try taking another photo? theres a red dot but inclear what it is
