Dear support
I want to use two breakout boards in my project.
The BNO055 orientation sensor together with the TSL2591.
The I^2C address of BNO can be selected between 0x28 and 0x29 and the TSL2591 uses 0x28 and 0x29 and cannot be changed.
Therefore I have an address conflict between this two modules. Do you see a solution to use both oft this breakout boards on the same I^2C controller?
Or is the only solution to use two different I^2C ports (which I try to avoid) to spare GPIO pins.
Best regards
Simon
BNO055 and TSL2591 I^2C address conflict.
- SimonBoonstra
- adafruit_support_bill
Re: BNO055 and TSL2591 I^2C address conflict.
You can use an i2c multiplexer to switch between up to 8 i2c buses:
https://www.adafruit.com/product/2717
