This sensor seemed to work well for the first week, then the AQI values started reading unnaturally high.
https://www.adafruit.com/product/3686), which returned low to zero AQI at the same time this was reading "Unhealthy" levels (the zero reading was indoors next to an air purifier). I didn't expect them to match, but they should be much closer.
The numbers below are with the sensor sealed in a case for a few days. I still expect some very small particles (as seen there) and no larger particles (still seen there), but then why is it coming back with a high AQI and concentration units?
Is there a way to "reset" the sensor or do I have a defective unit?
I ran it alongside a neighbor's Purple outdoor air sensor (which looks to use two of the PMS5003 sensors - PMSA003I Air Quality Sensor Issues
- adafruit_support_carter
Re: PMSA003I Air Quality Sensor Issues
Are you seeing the same behavior if your run the example from the library? Are you using Arduino or CircuitPython?
https://learn.adafruit.com/pmsa003i/overview
- mriesenberg
I'm using Circuit Python.
The sample code provides almost identical values (just about 2 minutes apart).
Example from Library: My code (which leverages the Example code):
What kind of environment was the sensor being used in for the week it was in operation?
What happened between March 14th and March 17th?
- mriesenberg
There had been some times it stopped feeding to IO and had to be rebooted (I haven't figured that issue out yet). During the 14-17th it was just unplugged and off.
It has spent most of its time indoors, with a few hours outside (day 2). Tested things like the fireplace and an air filter to see the data. It's been in the same room the rest of the time.
- thzinc
@mriesenberg, what are you using to calculate AQI?
I'm also working on a device that uses the PMS5003 and I'm seeing values for PM1 and PM10 concentrations that seem like they're transposed: viewtopic.php?f=19&t=190859
- mriesenberg
I used the code from this guide: https://learn.adafruit.com/air-quality- ... thon-setupthzinc wrote:@mriesenberg, what are you using to calculate AQI?
And used in the same location / environment between each time it used in this time frame? Is it known and expected that the environment's AQI should *not* have actually changed?During the 14-17th it was just unplugged and off.
- mriesenberg
Correct. And the delta between the Purple air sensor (it was reading 0-20 AQI) and mine increased when they were side-by-side.adafruit_support_carter wrote:And used in the same location / environment between each time it used in this time frame? Is it known and expected that the environment's AQI should *not* have actually changed?During the 14-17th it was just unplugged and off.
Additionally, March 28th is when I tried sealing the case and it still read high for those last days.
Can you link to your full code that is reporting the AQI values.
Did you happen to look at the other values to see if any of those had similar jumps?
- mriesenberg
This is the AQI calc function:
And here's the full code:
def calculate_aqi(pm_sensor_reading):
"""Returns a calculated air quality index (AQI)
and category as a tuple.
NOTE: The AQI returned by this function should ideally be measured
using the 24-hour concentration average. Calculating a AQI without
averaging will result in higher AQI values than expected.
:param float pm_sensor_reading: Particulate matter sensor value.
# Check sensor reading using EPA breakpoint (Clow-Chigh)
if 0.0 <= pm_sensor_reading <= 12.0:
# AQI calculation using EPA breakpoints (Ilow-IHigh)
aqi_val = map_range(int(pm_sensor_reading), 0, 12, 0, 50)
aqi_cat = "Good"
elif 12.1 <= pm_sensor_reading <= 35.4:
aqi_val = map_range(int(pm_sensor_reading), 12, 35, 51, 100)
aqi_cat = "Moderate"
elif 35.5 <= pm_sensor_reading <= 55.4:
aqi_val = map_range(int(pm_sensor_reading), 36, 55, 101, 150)
aqi_cat = "Unhealthy for Sensitive Groups"
elif 55.5 <= pm_sensor_reading <= 150.4:
aqi_val = map_range(int(pm_sensor_reading), 56, 150, 151, 200)
aqi_cat = "Unhealthy"
elif 150.5 <= pm_sensor_reading <= 250.4:
aqi_val = map_range(int(pm_sensor_reading), 151, 250, 201, 300)
aqi_cat = "Very Unhealthy"
elif 250.5 <= pm_sensor_reading <= 350.4:
aqi_val = map_range(int(pm_sensor_reading), 251, 350, 301, 400)
aqi_cat = "Hazardous"
elif 350.5 <= pm_sensor_reading <= 500.4:
aqi_val = map_range(int(pm_sensor_reading), 351, 500, 401, 500)
else:
print("Invalid PM2.5 concentration")
aqi_val = -1
aqi_cat = "None"
return aqi_val, aqi_cat
# SPDX-FileCopyrightText: 2020 Brent Rubell for Adafruit Industries
import time
import board
import busio
from digitalio import DigitalInOut
import neopixel
from adafruit_esp32spi import adafruit_esp32spi, adafruit_esp32spi_wifimanager
from adafruit_io.adafruit_io import IO_HTTP
from simpleio import map_range
from adafruit_pm25.uart import PM25_UART
from analogio import AnalogIn
# Uncomment below for PMSA003I Air Quality Breakout
from adafruit_pm25.i2c import PM25_I2C
import adafruit_bme280
### Configure Sensor ###
# Return environmental sensor readings in degrees Celsius
USE_CELSIUS = False
# Interval the sensor publishes to Adafruit IO, in minutes
PUBLISH_INTERVAL = 1
### WiFi ###
# Get wifi details and more from a secrets.py file
try:
from secrets import secrets
except ImportError:
print("WiFi secrets are kept in secrets.py, please add them there!")
raise
# AirLift FeatherWing
esp32_cs = DigitalInOut(board.D13)
esp32_reset = DigitalInOut(board.D12)
esp32_ready = DigitalInOut(board.D11)
spi = busio.SPI(board.SCK, board.MOSI, board.MISO)
esp = adafruit_esp32spi.ESP_SPIcontrol(spi, esp32_cs, esp32_ready, esp32_reset)
status_light = neopixel.NeoPixel(board.NEOPIXEL, 1, brightness=0.2)
wifi = adafruit_esp32spi_wifimanager.ESPSPI_WiFiManager(esp, secrets, status_light)
# Connect to a PM2.5 sensor over UART
reset_pin = None
# uart = busio.UART(board.TX, board.RX, baudrate=9600)
# pm25 = PM25_UART(uart, reset_pin)
# Create i2c object
i2c = busio.I2C(board.SCL, board.SDA, frequency=100000)
# Connect to a BME280 over I2C
# bme_sensor = adafruit_bme280.Adafruit_BME280_I2C(i2c)
pm25 = PM25_I2C(i2c, reset_pin)
# Uncomment below for BME680
import adafruit_bme680
bme_sensor = adafruit_bme680.Adafruit_BME680_I2C(i2c)
### Sensor Functions ###
aqi_cat = "Good"
else:
aqi_val = -1
aqi_cat = "None"
def sample_aq_sensor():
"""Samples PM2.5 sensor
over a 2.3 second sample rate.
aq_reading = 0
aq_samples = []
# initial timestamp
time_start = time.monotonic()
# sample pm2.5 sensor over 2.3 sec sample rate
while time.monotonic() - time_start <= 2.3:
try:
aqdata = pm25.read()
aq_samples.append(aqdata["pm25 env"])
except RuntimeError:
print("Unable to read from sensor, retrying...")
continue
# pm sensor output rate of 1s
time.sleep(1)
# average sample reading / # samples
for sample in range(len(aq_samples)):
aq_reading += aq_samples[sample]
aq_reading = aq_reading / len(aq_samples)
aq_samples.clear()
return aq_reading
def read_bme(is_celsius=False):
"""Returns temperature, gag, pressure, and humidity
from BME280/BME680 environmental sensor, as a tuple.
:param bool is_celsius: Returns temperature in degrees celsius
if True, otherwise fahrenheit.
humid = bme_sensor.humidity
temp = bme_sensor.temperature
gas = bme_sensor.gas
pressure = bme_sensor.pressure
if not is_celsius:
temp = temp * 1.8 + 32
return temp, humid, gas, pressure
# Get current voltage reading
vbat_voltage = AnalogIn(board.VOLTAGE_MONITOR)
def get_voltage(pin):
return (pin.value * 3.3) / 65536 * 2
battery_voltage = get_voltage(vbat_voltage)
# Create an instance of the Adafruit IO HTTP client
io = IO_HTTP(secrets["aio_username"], secrets["aio_key"], wifi)
# Describes feeds used to hold Adafruit IO data
feed_aqi = io.get_feed("air-quality.aqi")
feed_aqi_category = io.get_feed("air-quality.category")
feed_humidity = io.get_feed("air-quality.humidity")
feed_temperature = io.get_feed("air-quality.temperature")
feed_pressure = io.get_feed("air-quality.pressure")
feed_gas = io.get_feed("air-quality.voc")
feed_pm10 = io.get_feed("air-quality.pm10")
feed_pm25 = io.get_feed("air-quality.pm25")
feed_pm100 = io.get_feed("air-quality.pm100")
# Set up location metadata from secrets.py file
location_metadata = {
"lat": secrets["latitude"],
"lon": secrets["longitude"],
"ele": secrets["elevation"],
elapsed_minutes = 0
prv_mins = 0
while True:
try:
print("Fetching time...")
cur_time = io.receive_time()
print("Time fetched OK!")
# Hourly reset
if cur_time.tm_min == 0:
prv_mins = 0
except (ValueError, RuntimeError) as e:
print("Failed to fetch time, retrying\n", e)
wifi.reset()
wifi.connect()
continue
if cur_time.tm_min >= prv_mins:
print("%d min elapsed.." % elapsed_minutes)
prv_mins = cur_time.tm_min
elapsed_minutes += 1
if elapsed_minutes >= PUBLISH_INTERVAL:
print("Sampling AQI...")
aqi_reading = sample_aq_sensor()
aqi, aqi_category = calculate_aqi(aqi_reading)
print("AQI: %d" % aqi)
print("Category: %s" % aqi_category)
print()
print("---------------------------------------")
print("Concentration Units (standard)")
print(
"PM 1.0: %d\tPM2.5: %d\tPM10: %d"
% (aqdata["pm10 standard"], aqdata["pm25 standard"], aqdata["pm100 standard"])
print("Concentration Units (environmental)")
print(
% (aqdata["pm10 env"], aqdata["pm25 env"], aqdata["pm100 env"])
print("Particles > 0.3um / 0.1L air:", aqdata["particles 03um"])
print("Particles > 0.5um / 0.1L air:", aqdata["particles 05um"])
print("Particles > 1.0um / 0.1L air:", aqdata["particles 10um"])
print("Particles > 2.5um / 0.1L air:", aqdata["particles 25um"])
print("Particles > 5.0um / 0.1L air:", aqdata["particles 50um"])
print("Particles > 10 um / 0.1L air:", aqdata["particles 100um"])
# temp and humidity
print("Sampling environmental sensor...")
temperature, humidity, gas, pressure = read_bme(USE_CELSIUS)
print("Temperature: %0.1f F" % temperature)
print("Humidity: %0.1f %%" % humidity)
print("VOC: %d ohm" % gas)
print("Pressure: %0.3f hPa" % pressure)
print("Battery V: {:.2f}V".format(battery_voltage))
# Publish all values to Adafruit IO
print("Publishing to Adafruit IO...")
try:
io.send_data(feed_aqi["key"], str(aqi), location_metadata)
io.send_data(feed_aqi_category["key"], aqi_category)
io.send_data(feed_temperature["key"], str(temperature))
io.send_data(feed_humidity["key"], str(humidity))
io.send_data(feed_pressure["key"], str(pressure))
io.send_data(feed_gas["key"], str(gas))
io.send_data(feed_pm10["key"], str(aqdata["pm10 env"]))
io.send_data(feed_pm25["key"], str(aqdata["pm25 env"]))
io.send_data(feed_pm100["key"], str(aqdata["pm100 env"]))
print("Published!")
print("Failed to send data to IO, retrying\n", e)
wifi.reset()
wifi.connect()
continue
# Reset timer
elapsed_minutes = 0
time.sleep(30)
- mriesenberg
I didn't log the PM values before I started troubleshooting, but the PM2.5 and PM10 values have been high since I started doing so and in a sealed case they should be 0 (especially PM10, which are large particles).adafruit_support_carter wrote:Did you happen to look at the other values to see if any of those had similar jumps?
You are basing everything on the "pm25 env" value returned from the sensor.I still expect some very small particles (as seen there) and no larger particles (still seen there), but then why is it coming back with a high AQI and concentration units?
It could be that there are residual particles from the previous use. Like in the fireplace and air filter uses. Were those test environments fairly dirty?
- mriesenberg
I did test it with the fireplace going, but that was just a short time during the first day or two. The AQI went up and down as expected in the environment until it was turned back on later. I tried lightly blowing compressed air around it just to see if something got gunked up, but that didn't seem to do anything,
- adafruit2
you could try opening it up and cleaning it out, could be the area where the air travels through got dirty enough the particles are stuck to the sensor - in fact thats pretty likely what happened.
