Hi, I am trying to get a tilt switch and an Adafruit 1400 push button to start an ESP8266 board. After 2 minutes, one of the digital pins will go high and turn off the board. The Adafruit 1400 is potted in resin to make a kind of dongle thing that you invert to activate the tilt switch.
The dongle thing and Adafruit 1400 work fine on their own, the LED comes on and I get 6.4 V between the output of the 1400 & ground. When the output wire and the off wire are connected to the ESP 8266 board it stops working. There is a schematic of the circuit uploaded.
Any ideas?
Adafruit 1400
- Crichtd
Adafruit 1400
- Attachments
- Capture.JPG (47.32 KiB) Viewed 203 times
Re: Adafruit 1400
Does the circuit work with the Push-Button Power Switch's output connected to power on the ESP8266 board, but no connection to the PBPS's OFF pin?
- Crichtd
Re: Adafruit 1400
Thanks for your question. No, the Adafruit 1400 stops working if either the green or yellow wires are connected.
Re: Adafruit 1400
Post a photo of the actual hardware please. 800x600 images usually work best.
- Crichtd
Re: Adafruit 1400
I am not sure that the photos will help but they are uploaded. The schematic is much clearer. 1 is the Adafruit 1400 potted in resin, 2 is the ESP8266, battery etc.
- Attachments
- 2.JPG (263.56 KiB) Viewed 153 times
- 1.JPG (95.16 KiB) Viewed 153 times
Re: Adafruit 1400
I don't see any obvious source of problems, but the connections are hard to follow.
The best suggestion I have is to check the voltage on the lines that connect to the Push-Button Power Switch to make sure they carry the correct voltage.
