Just soldered headers to my Teensy 4, but when I add the Audio shield, it seems to turn off. What can go wrong?
I put female headers on the Teensy (2x14 pins) and male under the audio, so reversed stacking order, but I would not think that is a problem.
I added this chip to the memory solder islands:
Cypres S25FL128L
All joints look nice soldered under a big magnifying glass.
Teensy 4.0 LEDs go out after stacking Audio shield
- blnkjns
- michaelmeissner
Re: Teensy 4.0 LEDs go out after stacking Audio shield
Just to be sure, did you use revision D of the audio shield? Note, revision A-C of the audio shield is for the Teensy 3.2/3.5/3.6. Revision D is for the Teensy 4.0/4.1 microprocessors (the I2S pinout is different between the two).
You might want to post this query over at the forums at pjrc.com (which is the default site for Teensies). Please post pictures of your soldering attachment.
- blnkjns
Here are three images.
- photo_2022-05-20_22-19-15.jpg (182.17 KiB) Viewed 134 times
- photo_2022-05-20_22-19-19.jpg (164.71 KiB) Viewed 134 times
- photo_2022-05-20_22-19-22.jpg (188.97 KiB) Viewed 134 times
- blnkjns
And the last one
- photo_2022-05-20_22-19-11.jpg (173.47 KiB) Viewed 134 times
- blnkjns
After desoldering the memory chip, the shield no longer disables the Teensy. Probably an incompatible pin layout.
Edit: it was 180° turned around. Now I see the dot on the photo, the other side looked it had a notch so I aligned that.
- michaelmeissner
It is great that you found it. I've done that a few times myself.
