When the ENABLE is triggered by the 5111, the OUTPUT pins on the Huzzah go HIGH for a moment before the system even reaches the SETUP code. So this turns off the HUZZAH immediately on triggering the ENABLE. I've tried putting in a cap and resistor between the OUTPUT pin and the DONE pin on the 5111 but that doesn't work either.
Suggestions? I've tried the 5111 and 5110 and both suffer from the same issue.
TPL5111 does not work with Feather HUZZAH ESP8266
- jsada
- jsada
Re: TPL5111 does not work with Feather HUZZAH ESP8266
As a note, I implemented this EXACT schematic and it does NOT work. https://learn.adafruit.com/adafruit-tpl ... kout/usage
- Franklin97355
Are you running the example code in the tutorial and have the pot turned to the right? What value is the pot set at?
- jsada
I have run the code. I have also removed all the neopixel lines and run JUST the timer code. I have tried with the pot in various positions. None of it matters. As soon as the Huzzah starts, it puts the output pins high, which turns off the TPL5111 even before it gets a chance to set the pin to LOW in the setup() function.
- jsada
If I unhook the DONE pin and hit the enable button, then wait until SETUP() is done and reattach the DONE pin, then everything works fine. So it is entirely that the Feather puts the pins HIGH before hitting SETUP(). Can anything be done about this?
