Mini Thermal Printer Not Printing Correctly/At All
mantismei
Post by mantismei »
Hi, I'm fairly new to all of this and I've been having a couple of issues with my printer:
1: the test prints out ~12cm of blank paper
2: following the instructions from https://learn.adafruit.com/mini-thermal ... controller , I loaded A_printertest onto my Arduino and this was what it printed instead:
This is my set up. The Arduino is connected to my laptop USB port, I have it set at 5V. Baudrate at 19200 like what the Selftest sheet lists.
Another thing I tried: I connected the printer to a 9V battery while disconnected from the Arduino + while connected with the laptop-powered Arduino. Either way, the light started blinking faster, but it refused to print altogether. I also tried to switch RX and TX, but that seemed to make it print out even less, so probably not the solution here.
All help is appreciated!
adafruit_support_mike
Re: Mini Thermal Printer Not Printing Correctly/At All
The thermal printer wants at least 1.5A of current. It takes a lot of power to run the resistors on the thermal print head.
In the photo, it looks like you're getting power from the Arduino, which in turn gets power from a USB cable. That's known to fail:
https://learn.adafruit.com/mini-thermal ... nter/power
Try powering the printer separately, using at least a 2A @ 5V power supply.
mantismei
Post by mantismei »
Thanks for this, I didn't realize the Arduino power source could be a problem. All is running smoothly now!
Yep.. it takes a lot of current to make the array of resistors in the thermal print head heat up.
Glad to hear things are working for you. Happy hacking!
