I set it up with one sound file to get the project going. I want to change and add more sound files. Now, when I plug the USB into the back of the sound-board, it comes up as a speaker (VS1000B) and not a USB device as it did before.
Any suggestions?
Thanks in advance, sorry to be a pain in the butt.
Nick
I see the red LED is lit. Should I desolder the power wires from the LOLIN ESP8266 Pro? Disconnect the speaker. No, the 8266 is not powered up.Doesn't show up as a drive on my computer
Make sure the green LED near the microUSB port is lit, that tells you it has power, however the red LED should not be lit
Disconnecting the speaker didn't work.
Ah ha. Disconnecting the data wire from the ESP did the trick.
