Hi again,
I have successfully used the charger, with external LEDs, and everything seems to be working fine. I'm now double checking the whole setup before I enclose it in my project. I would rather have things right now than having to open the everything up later.
Since I wanted to use 3 of your small solar cells to charge the battery, I put a Schottky diode on the negative side of each panel to protect them in case of partial shading. I didn't put anything on the positive side. Should there be a diode on that side too or is the one I put in place sufficient?
Also, I have connected to the charger using the DC IN lines. This is because I have a SPDT switch to select either the panels or a wall wart to charge the battery: I didn't want to have to plug and unplug anything. Should there be a diode to protect against reverse current on the line going to the wall wart?
Vince
USB / DC / Solar Lithium Ion/Polymer charger
- vgvallee
Re: USB / DC / Solar Lithium Ion/Polymer charger
One is enough.Should there be a diode on that side too or is the one I put in place sufficient?
No need for that.Should there be a diode to protect against reverse current on the line going to the wall wart?
- john444
My setup flashes the charging LED current as low as 1-mA.cordstar wrote:Is there a minimum charge current from a 6v solar module for the solar charger to charge the battery?
The panel is not in direct sunlight but inside next to a window.
Although, at 1-mA it is going to take a very loooooooooong time to charge a decent capacity battery.
Cool, thanks for the reply John, I am putting together about 300 mA of 6v panel, just waiting for a minty boost kit. Would have been handy to have a 5v boost circuit already built in to the solar charger circuit, but all good, just hoping I can solder the minty boost bits together ok. Thanks again.
