Small Arcade Joystick (product 480)
Re: Small Arcade Joystick (product 480)
Add this to your code after the digitalRead statements. Then look at the output on the Serial Monitor when you move the joystick.
Serial.print("1-");
Serial.print(state1);
Serial.print(" 2-");
Serial.print(state2);
Serial.print(" 3-");
Serial.print(state3);
Serial.print(" 4-");
Serial.print(state4);
mscholl
Post by mscholl »
I keep getting an error message saying that serial doesnot have a name type
mscholl
Post by mscholl »
oops that would be serial does not name a type
mscholl
Post by mscholl »
Ok, got it going, but there is a never ending line going really fast with repeating "4-0-1 3-1 2-1 " It does not appear to change numbers when I press the joystick......
Change the last "print" to a "println"and add a delay. That should make the output easier to follow:
Serial.print("1-");
Serial.println(state4);
delay(250);
mscholl
Post by mscholl »
at rest and when I push the joystick forward I get: 1-1 2-1 3-1 4-0
when I push backward, I get 1-1 2-0 3-1 4-0
when I want to go right I get 1-0 2-1 3-1 4-0
when I want to go left I get 1-1 2-1 3-0 4-0
So switch #4 seems to be stuck closed. Double check your wiring. Make sure you don't have any short-circuits and everything is connected to the right pins.
mscholl
Post by mscholl »
I wired a different digital joystick and still no success. So then I took the wire to pin13 and moved it to pin 6. (seem to remember reading that pin13 is "special") Then I switched out pin 13 in the program for pin 6. AND IT WORKED!!!! But only in 3 directions, and the last was wanting to turn, but not well. I added the extra battery pack, since it did not seem like I was getting enough power with just the USB plugged in, and now it works in all directions. Now I just need to figure out how to hard wire it in.....So what is funky about pin13? Thanks for all your help!
Pin 13 on many Arduinos is connected to the on-board LED. That can affect readings when in INPUT mode.
Good to hear it is working for you now. Thanks for the follow-up.
