C:\___a_projects\libraries\RTClib\RTClib.cpp:7:22: warning: WProgram.h: No such file or directory
C:\___a_projects\libraries\RTClib\RTClib.cpp:17: warning: only initialized variables can be placed into program memory area
C:\___a_projects\libraries\RTClib\RTClib.cpp: In constructor 'DateTime::DateTime(uint32_t)':
C:\___a_projects\libraries\RTClib\RTClib.cpp:51: warning: comparison between signed and unsigned integer expressions
C:\___a_projects\libraries\RTClib\RTClib.cpp: In member function 'uint8_t RTC_DS1307::isrunning()':
C:\___a_projects\libraries\RTClib\RTClib.cpp:133: error: 'class TwoWire' has no member named 'send'
C:\___a_projects\libraries\RTClib\RTClib.cpp:137: error: 'class TwoWire' has no member named 'receive'
C:\___a_projects\libraries\RTClib\RTClib.cpp: In static member function 'static void RTC_DS1307::adjust(const DateTime&)':
C:\___a_projects\libraries\RTClib\RTClib.cpp:143: error: 'class TwoWire' has no member named 'send'
The code compiles fine with 0022 and mpide.
Probably something really simple. Is there an easy fix?
