DS18B20 Temp Sensor
DS18B20 Temp Sensor
by SaltySteve on Thu Nov 22, 2012 3:06 am
I just ordered the waterproof version of the DS18B20 Temp. Sensor, and I am hoping that it will be fit for use in a salt water aquarium.
Is it?
Will it stand up over time being completely submerged in salt water?
SaltySteve
Re: DS18B20 Temp Sensor
by adafruit_support_bill on Thu Nov 22, 2012 7:29 am
I know some customers have purchased them for that purpose, but I haven't heard any feedback. The tip sheath is stainless, but as you probably know - that alone is not a guarantee of survival in salt water. I'd consider passivating it before deploying in a marine aquarium:
http://www.howtobrew.com/appendices/appendixB-1.html
by Mage on Sun Jul 17, 2016 2:47 pm
I have had two "Waterproof DS18B20" temperature sensors fail in my saltwater aquarium. :-(
Mage
by rohanaby79 on Tue Jul 19, 2016 10:30 am
I would like to know if there is a temperature sensor that can be mounted onto the object.
rohanaby79
by adafruit_support_bill on Tue Jul 19, 2016 11:01 am
What object do you want to mount it on?
by rohanaby79 on Tue Jul 19, 2016 11:08 am
I would like to mount it on electrical components like a processor, battery in a Vaccum environment. Also, the sensor should not be conductive.
rohanaby79
by adafruit_support_bill on Tue Jul 19, 2016 11:11 am
The plastic bodied DS18B20 or TMP-36 could be glued to a surface with a thermal adhesive such as ArcticSilver.
https://www.adafruit.com/products/374
https://www.adafruit.com/products/165
There are insulated thermocouple probes designed for surface mounting, but they usually need to be bolted on.
by rohanaby79 on Tue Jul 19, 2016 11:22 am
Do you have insulated thermocouple probes?
rohanaby79
by rohanaby79 on Tue Jul 19, 2016 11:26 am
Also, can the plastic temp sensor withstand like 70 C?
rohanaby79
by adafruit_support_bill on Tue Jul 19, 2016 11:37 am
We do not stock insulated thermocouples. They are available from most industrial supply sources. Omega Engineering usually has the most extensive selection.
Both the DS18B20 and TMP36 in plastic packages are rated for up to 125C.
by rohanaby79 on Tue Jul 19, 2016 11:39 am
Ok, Thanks a lot for your help.
rohanaby79
