AM2315 Bad Data after 12 reads- some new info
Re: AM2315 Bad Data after 12 reads- some new info
//Serial.println(reply[i], HEX);
#include <Wire.h>
#include <Adafruit_AM2315.h>
This is an example for the AM2315 Humidity + Temp sensor
Designed specifically to work with the Adafruit BMP085 Breakout
----> https://www.adafruit.com/products/1293
These displays use I2C to communicate, 2 pins are required to
interface
products from Adafruit!
// Connect RED of the AM2315 sensor to 5.0V
// Connect BLACK to Ground
// Connect WHITE to i2c clock - on '168/'328 Arduino Uno/Duemilanove/etc thats Analog 5
// Connect YELLOW to i2c data - on '168/'328 Arduino Uno/Duemilanove/etc thats Analog 4
Adafruit_AM2315 am2315;
Serial.println("AM2315 Test!");
if (! am2315.begin()) {
Serial.println("Sensor not found, check wiring & pullups!");
while (1);
Serial.print("Hum: "); Serial.println(am2315.readHumidity());
delay(2); //<-- ADDED BY ESG TO ELIMINATE BAD DATA PROBLEM, NOT PART OF ORIGINAL EXAMPLE
Serial.print("Temp: "); Serial.println(am2315.readTemperature());
delay(1000);
New AM2315 Library- Temp & Humidity in a single function call
This is a library for the AM2315 Humidity Pressure & Temp Sensor
Designed specifically to work with the AM2315 sensor from Adafruit
interface
Additional improvements added by Daniel Sandoval/EasternStarGeek
8 July, 2013. (Parent Library: Adafruit_AM2315)
#if (ARDUINO >= 100)
#include "Arduino.h"
#else
#include "WProgram.h"
#endif
#include "Wire.h"
#define AM2315_I2CADDR 0x5C
#define AM2315_READREG 0x03
class ESG_AM2315 {
public:
ESG_AM2315();
//boolean begin(void);
boolean readData(float *dataArray);
private:
float humidity, temp;
This is a library for the AM2315 Humidity & Temp Sensor
interface
#include "ESG_AM2315.h"
#include <util/delay.h>
ESG_AM2315::ESG_AM2315() {
boolean ESG_AM2315::readData(float *dataArray) {
uint8_t reply[10];
Wire.beginTransmission(AM2315_I2CADDR);
Wire.write(AM2315_READREG);
Wire.write(0x00); // start at address 0x0
Wire.write(4); // request 4 bytes data
Wire.endTransmission();
// for reasons unknown we have to send the data twice :/
// whats the bug here?
Wire.requestFrom(AM2315_I2CADDR, 8);
for (uint8_t i=0; i<8; i++) {
reply[i] = Wire.read();
if ((reply[0] == AM2315_READREG) &&
(reply[1] == 4)) {
humidity = reply[2];
humidity *= 256;
humidity += reply[3];
humidity /= 10;
dataArray[0] = humidity;
temp = reply[4];
temp *= 256;
temp += reply[5];
temp /= 10;
dataArray[1] = (temp * 1.8)+32;
return true;
else {
dataArray[0] = NAN;
dataArray[1] = NAN;
return false;
#include <Wire.h>
#include <ESG_AM2315.h>
interface
This version gets the Temperature and Humidity data with a single read, and is
believed to solve some prior timing problems in the original.
Be careful with return data array indexing! Follow this example closely.
ESG_AM2315 am2315;
float dataAM2315[2]; //Array to hold data returned by sensor. [0,1] => [Humidity, Temperature]
boolean OK; // 1=successful read
OK = am2315.readData(dataAM2315);
if (OK) {
Serial.print("Hum: "); Serial.println(dataAM2315[0]);
Serial.print("TempF: "); Serial.println(dataAM2315[1]);
else
delay(1000);
EasternStarGeek wrote:The trick is to not read the sensor too frequently. (like <10mS interval).
delay(3);
