I've got the Pi set up and working with both eth0 and wlan0 on my "normal" network, so I know that the hardware works. I'm running the latest Raspbian but can NOT get hosted to work right. I'm following the how to over at learning.adafruit to set up a WAP, including downloading the Adafruit-compiled hostapd. This is my hostapd.conf:
- Code: Select all | TOGGLE FULL SIZE
interface=wlan0
driver=rtl871xdrv
ssid=Pi_AP
hw_mode=g
channel=6
macaddr_acl=0
auth_algs=1
ignore_broadcast_ssid=0
wpa=2
wpa_passphrase=Raspberry
wpa_key_mgmt=WPA-PSK
wpa_pairwise=TKIP
rsn_pairwise=CCMP
Here is the output that I get when trying to start hostapd
Configuration file: /etc/hostapd/hostapd.conf
drv->ifindex=3
l2_sock_recv==l2_sock_xmit=0x0x10ce638
+rtl871x_sta_deauth_ops, ff:ff:ff:ff:ff:ff is deauth, reason=2
rtl871x_set_key_ops
rtl871x_set_key_ops
rtl871x_set_key_ops
rtl871x_set_key_ops
Using interface wlan0 with hwaddr 00:13:ef:d0:2a:ca and ssid 'Pi_AP'
rtl871x_set_wps_assoc_resp_ie
rtl871x_set_wps_beacon_ie
rtl871x_set_wps_probe_resp_ie
rtl871x_set_key_ops
rtl871x_set_beacon_ops
rtl871x_set_hidden_ssid_ops
ioctl[RTL_IOCTL_HOSTAPD]: Invalid argument
I'm thinking that I might need a new (compatible?) driver to go with the latest raspbian, but the instructions for THAT are out of date on the adafruit website, too. :(
Any suggestions would be VERY appreciated
