Black Lives Matter - Action and Equality. ... Adafruit is part of the Stop Hate for Profit campaign. Adafruit is open and shipping.
DHT 22 Temperature and Humidity sensor with adafruit code
Re: DHT 22 Temperature and Humidity sensor with adafruit cod
by kamak on Mon Jun 25, 2018 8:39 pm
Hi, had a bit of time to do some googling, and have managed to get the google spreadsheet script kind of working using 'strftime' – this will format the date and time as a string which can be sent to google sheets (so not formatted as date / time, but ok for my purposes). Bear in mind that I've no real idea what I'm doing, I'm just hacking stuff together from google searches. No doubt there's a better solution than this.
Declare a couple of variables in the 'while' loop, at around line 114, and print them.
(You could use one variable, but better for my purposes to split the date from the time).
    date_str = json.dumps(datetime.datetime.now().strftime("%Y-%m-%d"))
    time_str = json.dumps(datetime.datetime.now().strftime("%H:%M:%S"))
    print(date_str)
    print(time_str)
Then modify the 'append to worksheet' line, to include the variable(s) instead of datetime:
       worksheet.append_row((date_str, time_str, temp, humidity))
Writes to google sheets ok.
Looks possible to modify the string(s) in google sheets after logging, so will be recognised as a date / time, but I've no need for it.
Cheers
kamak
