CUPCADE: "A" button not working.
by DestroJames on Fri May 02, 2014 3:24 pm
Just finished the Cupcade build. Thanks for a great project.
I am doing a dry run and screen, sound, joystick and buttons all are working okay, but only the A button isn't working.
I checked the button and wire goes to ground and 21/27 on T cobbler correctly.
I am trying to find out the meaning of #21 (v1) / #27 (v2) on the cobbler.
Could it mean that I have an older version of Pi that uses a different pin?
If so, is there any way I can re-map the pin?
DestroJames
Re: CUPCADE: "A" button not working.
by pburgess on Fri May 02, 2014 10:45 pm
The GPIO header changed slightly from "version 1" Pis to version 2. It's easy to spot the difference: v2 boards have two mounting holes (one near the USB jack, the other just below the Raspberry Pi logo). Some info on the pin changes here:
http://elinux.org/RPi_Low-level_periphe ... .28GPIO.29
If you have a v1 board, the "A" button and left & right on the joystick won't work. But it's fixable if you don't mind editing a little code.
As I recall the "retrogame" source (which handles the GPIO to keyboard conversion) is in /usr/local/src/retrogame. Or, if it's not there, you can download it by typing:
wget https://github.com/adafruit/Adafruit-Retrogame/archive/master.zip
There's a table starting around line 94. Each line is a GPIO pin number and a corresponding key. Change the pin numbers 2, 3 and 27 to 0, 1 and 21, respectively. Recompile with:
make CFLAGS=-DCUPCADE
sudo make install
Rather than tracking down and restarting retrogame, it's easiest just to reboot.
sudo reboot
If I'm wrong and you have a rev2 board (the vast majority of them are), then it's probably a wonky connection somewhere...either with the soldering, or something not right in the jumper wires or the button (in which case we'll get you a replacement). If you don't have a multimeter to test the button with, it's easy to check just by physically swapping the "A" and "B" buttons...does the problem now move to "B"? If so, bum button. If not, suspicious wire or soldering.
And thank you for doing the dry run first! I'd feel terrible if you'd squeezed it all into the case only to encounter gremlins.
pburgess
by DestroJames on Mon May 05, 2014 1:06 pm
Your solution worked!
Since "Y" on the stick worked at the game select screen, I assumed the joystick was working at first, but I found that X axis didn't work once I got a game loaded. Also, my Pi didn't have any mounting holes.
So I followed the instruction and (all source files were already present) now all controls work. I have to wrestle with the enclosure at a later time, so no Jousting yet, but I wanted to report all is working great now.
Thanks a lot for your quick reply!
DestroJames
by cherybomb on Wed May 07, 2014 8:09 pm
hi
I followed the step to install retrogame, but I have this error.
cherybomb
by pburgess on Thu May 08, 2014 1:44 am
cherybomb: I need to know more about how you got to this step. Are you building a Cupcade from the kit, or getting the software running on your own setup? Did you download the preconfigured Cupcade SD image, or are you working from another OS such as Raspbian? What version of the Raspberry Pi board do you have? Does it have mounting holes, or is it one of the early models? (uncommon)
pburgess
by cherybomb on Sun May 11, 2014 11:18 pm
Hi
I use
-RPI model b
-I configure pitft on raspian
cherybomb
by pburgess on Tue May 13, 2014 3:28 am
Looks like the two programs haven't been compiled before trying to install; it's running some other version, probably the original MAME-on-Pi tutorial, which uses a different pinout. So...in the retrogame directory, first type:
make clean; make CFLAGS=-DCUPCADE
and if that works, then type:
sudo make install
If you have an early Model B board (one without mounting holes), there will be some changes needed in the retrogame code.
pburgess
by cherybomb on Sun Jul 20, 2014 8:06 pm
How to change the code??
cherybomb
by pburgess on Mon Jul 21, 2014 3:58 pm
This post explains changing the retrogame code for V1 Pi boards:
viewtopic.php?f=19&t=53557&p=273255&hilit=retrogame+v1#p270779
This is -only- necessary if you have a V1 board (no mounting holes).
pburgess
by davidwhitt46 on Mon Dec 05, 2016 1:40 pm
hi just make might but try /usr/local/src/retrogame but non ther
download wget https://github.com/adafruit/Adafruit-Re ... master.zip
i dont how to install it now download it and what i do after
davidwhitt46
