gatttool or python interface to nRF8001?
by nouyang2 on Mon Jun 30, 2014 8:08 pm
I am wondering if anyone has been able to talk from their computer to the arduino+nRF8001 breakout.
So far I have gotten to:
nrw@nrw-PC:~$ sudo gatttool -b DC:05:4F:BC:F6:4A  -I -t random
[   ][DC:05:4F:BC:F6:4A][LE]> connect
[CON][DC:05:4F:BC:F6:4A][LE]> char-desc
handle: 0x0001, uuid: 2800
handle: 0x0002, uuid: 2803
handle: 0x0003, uuid: 2a00
handle: 0x0004, uuid: 2803
handle: 0x0005, uuid: 2a01
[CON][DC:05:4F:BC:F6:4A][LE]> char-write-req 0x0003 0x0067
[CON][DC:05:4F:BC:F6:4A][LE]> Characteristic value was written successfully
[CON][DC:05:4F:BC:F6:4A][LE]> char-write-cmd 0x0003 0x0067
and I am using a modified callBack_echo for the Arduino code.
https://github.com/adafruit/Adafruit_nR ... ckEcho.ino
On the Serial Monitor, I can see
Advertising started
Connected!
I expect that 0x0067 will transmit "g" but nothing happens on the Arduino (no serial monitor "byte received", no rgbLED color change). If I connect using Android 4.3 and the nRF UART application, then I can send and receive characters fine. Is there something else I need to do on the gatttool side to talk to the UART Arduino sketch?
The ultimate goal is to be able to broadcast data from a computer with a CSR4.0 dongle to several nRF8001 breakouts. I was able to do so using two CSR4.0 dongles on the computer*, but an Arduino is not a raspberry pi and a nRF8001 (slave-mode only) is not a CSR4.0 dongle. sad...
*http://www.orangenarwhals.com/?p=887
Any help appreciated.
System specs: atmega328p on a custom board programmed as a nano328 over usbasp, pins used:
#define ADAFRUITBLE_REQ A1
#define ADAFRUITBLE_RDY 2
#define ADAFRUITBLE_RST A0, data back from atmega via FTDI cable, ubuntu 13.10.
nouyang2
Re: gatttool or python interface to nRF8001?
by franklin97355 on Tue Jul 01, 2014 5:25 pm
I would check with the author of gatttool.
franklin97355
by ktownsend on Tue Jul 01, 2014 6:04 pm
I've had a lot of frustrations with GATTTool as well as the other related tools in Bluez where BLE is concerned (hcitool, etc.). The documentation is pretty sparse, and it's tough to make much sense of it where newer things like BLE are concerned (there's more info out there on Classic Bluetooth). :(
If you're able to get anything working with Bluez and GATTTool and the related command line tools for BLE, though, please feel free to post the details up here and we'll be happy to mention it on the blog so other people can benefit from it!
The best I could do in my limited attempts was connecting, but I didn't find the magic formula to send/receive data via GATT transactions after the connection was established. Admittedly, I didn't try as hard as I perhaps should have, but since all of the in house development was done using the tools from Nordic, Bluez got neglected early on.
Any submissions here are definitely welcome, but I'm afraid I don't have any good news to report saying that I was able to get this working with BLE myself beyond the initial connection.
ktownsend
by nouyang2 on Tue Jul 01, 2014 8:02 pm
WHOA I totally got it working :D
Here are the steps I took. Overview
1) updated from the bluez that is in ubuntu 14.04 package manager,
nrw@nrw-PC:~$ dpkg --status bluez | grep '^Version:'
Version: 4.101-0ubuntu13
to version 5.20
2) Using that, figured out the correct characteristic I should be writing to
I'm not sure how interlinked 1 and 2 are, presumably I didn't need to update bluez, I was just writing to the wrong characteristic ID yesterday.
phewwwww large order of nrf8001 breakouts not going to waste. hopefully.
In detail, with major help from http://www.jaredwolff.com/blog/get-star ... ow-energy/,
sudo apt-get remove bluez
sudo apt-get remove bluez-cups
sudo apt-get remove bluez-hcidump
~$  wget http://www.kernel.org/pub/linux/bluetooth/bluez-5.20.tar.xz
(I checked online to see what the latest version was at http://www.kernel.org/pub/linux/bluetooth/)
~$ tar xvf bluez-5.18.tar.xz
~/bluez-5.20$  ./configure --enable-library --disable-systemd
$ make -j8 && sudo make install
$ sudo cp attrib/gatttool /usr/local/bin/
nrw@nrw-PC:~$ sudo hcitool lescan
LE Scan ...
E9:D9:7A:EB:BC:35
E9:D9:7A:EB:BC:35 (unknown)
IN another terminal (not sure if the sec-level=high is needed)
nrw@nrw-PC:~$ sudo gatttool -b E9:D9:7A:EB:BC:35 -I -t random --sec-level=high
[E9:D9:7A:EB:BC:35][LE]> connect
Attempting to connect to E9:D9:7A:EB:BC:35
Connection successful
[E9:D9:7A:EB:BC:35][LE]> char-desc
handle: 0x0001, uuid: 00002800-0000-1000-8000-00805f9b34fb
handle: 0x0002, uuid: 00002803-0000-1000-8000-00805f9b34fb
handle: 0x0003, uuid: 00002a00-0000-1000-8000-00805f9b34fb
handle: 0x0004, uuid: 00002803-0000-1000-8000-00805f9b34fb
handle: 0x0005, uuid: 00002a01-0000-1000-8000-00805f9b34fb
handle: 0x0006, uuid: 00002803-0000-1000-8000-00805f9b34fb
handle: 0x0007, uuid: 00002a04-0000-1000-8000-00805f9b34fb
handle: 0x0008, uuid: 00002800-0000-1000-8000-00805f9b34fb
handle: 0x0009, uuid: 00002800-0000-1000-8000-00805f9b34fb
handle: 0x000a, uuid: 00002803-0000-1000-8000-00805f9b34fb
handle: 0x000b, uuid: 6e400002-b5a3-f393-e0a9-e50e24dcca9e
handle: 0x000c, uuid: 00002803-0000-1000-8000-00805f9b34fb
handle: 0x000d, uuid: 6e400003-b5a3-f393-e0a9-e50e24dcca9e
handle: 0x000e, uuid: 00002902-0000-1000-8000-00805f9b34fb
handle: 0x000f, uuid: 00002800-0000-1000-8000-00805f9b34fb
handle: 0x0010, uuid: 00002803-0000-1000-8000-00805f9b34fb
handle: 0x0011, uuid: 00002a27-0000-1000-8000-00805f9b34fb
Looks like we want 0x00b, the TX service according to https://learn.adafruit.com/getting-star ... pp-support
[E9:D9:7A:EB:BC:35][LE]> char-write-cmd 0x00b 0x0072
On the Serial Monitor:
Received 3 bytes: r [ 0x0 0x0 0x72 ]
   Writing out to BTLE: 0x0 0x0 0x72
Will write a blog post soon... Hurray!! Now to automate this with python.
nouyang2
by ktownsend on Tue Jul 01, 2014 8:13 pm
Thanks for the heads up. I'll test this out myself on my end. Ping us at support@adafruit.com with a link to this thread when you have a blog post up and I'll be happy to get it posted here as well!
ktownsend
by nouyang2 on Wed Jul 23, 2014 5:39 pm
Hi!
I wrote up how to script access in python (as opposed to entering commands one by one manually, now you can write a program to send values and therefore do things like build interactive robot apps in processing)
http://www.orangenarwhals.com/?p=911
The code for it all is here: https://gist.github.com/nouyang/2a6a733d8facd23115a4
Seems like the adafruit blog is busy, but putting this out there in case it's useful to others.
Happy hacking!
nouyang2
by 2h4u on Mon Apr 06, 2015 3:15 am
I figured out how to "read" from the nRF8001, hope this helps someone:
(I used the the same setup as nouyang2, ubuntu 14.04 with bluez-5.20)
First we need to set the notificationflag,
this is done with the command "char-write-req e 0100"
On the console of your computer:
sudo gatttool -b C0:85:BB:47:91:38 -I -t random
[C0:85:BB:47:91:38][LE]> connect
Attempting to connect to C0:85:BB:47:91:38
[C0:85:BB:47:91:38][LE]> char-write-req e 0100
Now lets try to write something from the nRF8001 to our computer:
Arduino serial monitor:
Adafruit Bluefruit Low Energy nRF8001 Print echo demo
* Advertising started
* Connected!
* Sending -> "test"
   Writing out to BTLE: 0x74 0x65 0x73 0x74
Notification handle = 0x000d value: 74 65 73 74
Got it! :D
Thanks to nouyang2 for providing all the information!
2h4u
by 2h4u on Tue Apr 07, 2015 6:06 am
I figured out how to send/receive to/from the nRF8001 with python.
There is a python api called bluepy: https://github.com/IanHarvey/bluepy
So its quit easy to interact with the NRF8001, here's a little test program:
from bluepy.btle import *
class NotificationHandler(DefaultDelegate):
    def handleNotification(self, cHandle, data):
        print('got response', data)
conn = Peripheral("C0:85:BB:47:91:38", "random")
conn.setDelegate(NotificationHandler())
try:
   # Turn on notificiations
    conn.writeCharacteristic(0x0e, '\x01\x00', False)
    # Send Message
   conn.writeCharacteristic(0x0b, 'test', False)
   # wait for response
   conn.waitForNotifications(1)
except Exception, e:
   print e
finally:
   conn.disconnect
Some notes about the setup:
Raspberry with Raspian 3.18.7 and a BLE tongle
Python v2.7.3
Bluepy v0.9.0
nRF8001
Arduino Leonardo with the callBackEcho programm from adafruit for testing responses
I hope this helps somebody, cause its not that easy to find some information about the nRF8001 and howto use it with other system then iOS or android.
Source: http://newscentral.exsees.com/item/56c36ee66609c793f73925d5cac53371-94f7996361fd456dd611116d4665e8e3
2h4u
by adafruit_support_mike on Tue Apr 07, 2015 10:00 pm
Nice1 Thanks for posting!
by chenglin on Tue Jan 19, 2016 11:47 pm
Hi all,
I am following nouyang2 and 2h4u. I want to read data from my adafruit NRF8001. Instead of using a laptop to receive data, I have a Intel Edison board which runs a Linux Yocto on it. I have installed the bluez-5.24 successfully. But when I want to write or read something from the NRF8001, it said "Command Failed: Disconnected".
[D2:AD:9F:B7:BB:60][LE]> connect
Attempting to connect to D2:AD:9F:B7:BB:60
[D2:AD:9F:B7:BB:60][LE]> char-write-req e 0100
Error: connect: Device or resource busy (16)
[D2:AD:9F:B7:BB:60][LE]> char-write-cmd 0x00b 0x0072
[D2:AD:9F:B7:BB:60][LE]> quit
root@SuperSensor:~# gatttool -b D2:AD:9F:B7:BB:60 -I -t random
[D2:AD:9F:B7:BB:60][LE]> char-desc
chenglin
