Hi Support,
We have 2 of our HDMI Touch screen (ID:2260) that are not working properly with our Raspberry-Pi 2 (we have many of them).
The screen does display properly but the "touch" is not working.
Every possible things has been checked and tested (even the USB cable).
As final test, I did connect all the screen we have (15+ pieces) on my Linux Mint computer to test the display and touch.
For those 2 screens with "touch failing" I did noticed a small change in the debug messages.
For all screens + touch that works properly have the 0003:04D8:0C02:xxxx as device identification.
For the screen presenting the touch issue, we have 0003:04D8:0C01:xxxx as device identification.
(Please see the commented picture showing dmesg for a working and another for the failing "touch" capability).
Any suggestion to make the touch working properly?
(ID:2260) Touch not acting for HDMI 5" 800x480 Display With
- mchobby
- Attachments
- HDMI-5Pc-Touch-screen issue.jpg (334.36 KiB) Viewed 599 times
Re: (ID:2260) Touch not acting for HDMI 5" 800x480 Display W
The AR1100 may have configured itself as a digitizer.
Try the instructions on this page to see if you can convince it to be a mouse again:
https://learn.adafruit.com/ar1100-resis ... guide/help
- mchobby
Great this worked fine :-)
Note: It has been necessary to plug the screen twice in order to be detected in the AR1100 configuration utility.
Thanks a lot.
Thanks a lot.
Glad to hear it's working for you.
