Battery Bad
TeslaNiklas
Battery Bad
Post by TeslaNiklas »
I am having trouble with the 3.7v battery. When I plug it in the project turns on and off. The ardunio is blinking and reloading. I tested the connectors with a multimeter and the power coming through is inconsistent. When I move the wires it responds better and then goes back to flickering on and off. It seems like the battery is bad. Could I get a replacement
adafruit_support_rick
Re: Battery Bad
What kind of Arduino?
Please post some picture of your setup
TeslaNiklas
Re: Battery Bad
The arduino is the Gemma. Here is the rough set up. It is now soldered.
P7221315 3.38.41 PM.jpg (440.95 KiB) Viewed 584 times
Re: Battery Bad
What are all those other wires connected to? If you disconnect everything else from the Gemma, does it stabilize?
What wires are you moving that make it work/not work?
Re: Battery Bad
[Thread moved to Other Adafruit Products]
TeslaNiklas
Re: Battery Bad
adafruit_support_rick wrote:What are all those other wires connected to? If you disconnect everything else from the Gemma, does it stabilize?
The project is similar to the drum set except we left out the switch. The Gemma is already soldered so we cannot remove pieces. Also, we connected the battery to a multimeter and are getting bad readings. We are moving the wires connected to the battery - positive/negative.
https://learn.adafruit.com/gemma-powere ... it-diagram
Re: Battery Bad
OK - Please email [email protected] with a link to this thread for a replacement battery
