SPDT switch
SPDT switch
by paulosophy on Tue Aug 18, 2015 11:45 am
Ok.... this is probably a super dumb question...
I'm trying to use an SPDT switch:
https://www.adafruit.com/product/805
I've got things wired so the left-most pin is going straight to ground, the right-most pin is going straight to 3.3V, and the middle pin has a 10K pull-down resistor from the pin input to ground, and then goes into pin #6. Photo (sorry about the bad quality):
http://i.imgur.com/l1nCJa3.jpg
When I move the switch to the "left-most" position, the board seems to go into bootloader mode:
https://www.youtube.com/watch?v=h6rm6uXEpbk
Could someone give some insight as to what's happening?
I feel like it should be simple to use a switch like this, so I'm probably doing some ding dong thing wrong.
paulosophy
Re: SPDT switch
by adafruit_support_bill on Tue Aug 18, 2015 12:02 pm
Does it work better if you remove the direct connection to ground from the left pin?
(leave the pulldown on the center pin)
Re: SPDT switch
by paulosophy on Tue Aug 18, 2015 12:30 pm
Yes it does! Thanks a lot.
Like the way you all use it here:
https://www.adafruit.com/products/2124? ... 5821456898
paulosophy
Re: SPDT switch
by adafruit_support_bill on Tue Aug 18, 2015 12:41 pm
Yes. I don't have one here, but I suspect that switch is "make-before-break" so it momentarily shorts the two end pins together as you switch it.
Re: SPDT switch
by paulosophy on Tue Aug 18, 2015 5:03 pm
Ahhhh cool. I learned something new today! Thanks :)
paulosophy
