Re: Bricked HUZZAH
by Ooozone on Thu Apr 21, 2016 3:15 am
@Adafruit Huzzah....Spent lot of time with the Problem #ESPcomm_open failed #espcomm_sync failed.
Plus, the progamming mode gets freezed and no matter how many times you press the reset or even change the power source, it will remain freeze in programming.
First I thought it is a issue with the board as i am succesfully programming 8266 boards from different vendors.
Tried so many methods like :
1. Providing a higher power source.
2. Using different FTDI and Serial chips for the uploading.
3. Connecting different pins with VCC and GND.
4. Changing the version of Arduino, ESP board from board manager, serial, com port, etc. But nothing worked.
Than after reading here a method (Miracle Method) I also tired this method...
1. Select the Generic board, baud 921600, reset method nodemcu etc according to the post from ADAFRUIT.
2. Hold the GPIO0 button and press RESET button, Release RESET button (dont release the GPIO0 button, keep it pressed). It will start uploading.
Thanks all for the help and thanks Adafruit.
