BMP280 with Python
BMP280 with Python
by bernd_p on Mon Feb 01, 2016 1:47 pm
Here my solution to get the values from the BMP280 in Python. Adafruit_GPIO is needed.
The sensor is connected to the Raspberry Pi I2C Bus
#coding: utf-8
import Adafruit_GPIO.I2C as I2C
import time
i2c = I2C
device=i2c.get_i2c_device(0x77) # address of BMP
# this value is necessary to calculate the correct height above sealevel
# its also included in airport wheather information ATIS named as QNH
# unit is hPa
QNH=1020
print("QNH:{:.0f}".format(QNH)+" hPA")
# power mode
# POWER_MODE=0 # sleep mode
# POWER_MODE=1 # forced mode
# POWER_MODE=2 # forced mode
POWER_MODE=3 # normal mode
# temperature resolution
# OSRS_T = 0 # skipped
# OSRS_T = 1 # 16 Bit
# OSRS_T = 2 # 17 Bit
# OSRS_T = 3 # 18 Bit
# OSRS_T = 4 # 19 Bit
OSRS_T = 5 # 20 Bit
# pressure resolution
# OSRS_P = 0 # pressure measurement skipped
# OSRS_P = 1 # 16 Bit ultra low power
# OSRS_P = 2 # 17 Bit low power
# OSRS_P = 3 # 18 Bit standard resolution
# OSRS_P = 4 # 19 Bit high resolution
OSRS_P = 5 # 20 Bit ultra high resolution
# filter settings
# FILTER = 0 #
# FILTER = 1 #
# FILTER = 2 #
# FILTER = 3 #
FILTER = 4 #
# FILTER = 5 #
# FILTER = 6 #
# FILTER = 7 #
# standby settings
# T_SB = 0 # 000 0,5ms
# T_SB = 1 # 001 62.5 ms
# T_SB = 2 # 010 125 ms
# T_SB = 3 # 011 250ms
T_SB = 4 # 100 500ms
# T_SB = 5 # 101 1000ms
# T_SB = 6 # 110 2000ms
# T_SB = 7 # 111 4000ms
CONFIG = (T_SB <<5) + (FILTER <<2) # combine bits for config
CTRL_MEAS = (OSRS_T <<5) + (OSRS_P <<2) + POWER_MODE # combine bits for ctrl_meas
# print ("CONFIG:",CONFIG)
# print ("CTRL_MEAS:",CTRL_MEAS)
BMP280_REGISTER_DIG_T1 = 0x88
BMP280_REGISTER_DIG_T2 = 0x8A
BMP280_REGISTER_DIG_T3 = 0x8C
BMP280_REGISTER_DIG_P1 = 0x8E
BMP280_REGISTER_DIG_P2 = 0x90
BMP280_REGISTER_DIG_P3 = 0x92
BMP280_REGISTER_DIG_P4 = 0x94
BMP280_REGISTER_DIG_P5 = 0x96
BMP280_REGISTER_DIG_P6 = 0x98
BMP280_REGISTER_DIG_P7 = 0x9A
BMP280_REGISTER_DIG_P8 = 0x9C
BMP280_REGISTER_DIG_P9 = 0x9E
BMP280_REGISTER_CHIPID = 0xD0
BMP280_REGISTER_VERSION = 0xD1
BMP280_REGISTER_SOFTRESET = 0xE0
BMP280_REGISTER_CONTROL = 0xF4
BMP280_REGISTER_CONFIG  = 0xF5
BMP280_REGISTER_STATUS = 0xF3
BMP280_REGISTER_TEMPDATA_MSB = 0xFA
BMP280_REGISTER_TEMPDATA_LSB = 0xFB
BMP280_REGISTER_TEMPDATA_XLSB = 0xFC
BMP280_REGISTER_PRESSDATA_MSB = 0xF7
BMP280_REGISTER_PRESSDATA_LSB = 0xF8
BMP280_REGISTER_PRESSDATA_XLSB = 0xF9
if (device.readS8(BMP280_REGISTER_CHIPID) == 0x58): # check sensor id 0x58=BMP280
    device.write8(BMP280_REGISTER_SOFTRESET,0xB6) # reset sensor
    time.sleep(0.2) # little break
    device.write8(BMP280_REGISTER_CONTROL,CTRL_MEAS) #
    device.write8(BMP280_REGISTER_CONFIG,CONFIG)  #
    time.sleep(0.2)
    # register_control = device.readU8(BMP280_REGISTER_CONTROL) # check the controll register again
    # register_config = device.readU8(BMP280_REGISTER_CONFIG)# check the controll register again
    # print("config:",register_config)
    # print("control:",register_control)
    dig_T1 = device.readU16LE(BMP280_REGISTER_DIG_T1) # read correction settings
    dig_T2 = device.readS16LE(BMP280_REGISTER_DIG_T2)
    dig_T3 = device.readS16LE(BMP280_REGISTER_DIG_T3)
    dig_P1 = device.readU16LE(BMP280_REGISTER_DIG_P1)
    dig_P2 = device.readS16LE(BMP280_REGISTER_DIG_P2)
    dig_P3 = device.readS16LE(BMP280_REGISTER_DIG_P3)
    dig_P4 = device.readS16LE(BMP280_REGISTER_DIG_P4)
    dig_P5 = device.readS16LE(BMP280_REGISTER_DIG_P5)
    dig_P6 = device.readS16LE(BMP280_REGISTER_DIG_P6)
    dig_P7 = device.readS16LE(BMP280_REGISTER_DIG_P7)
    dig_P8 = device.readS16LE(BMP280_REGISTER_DIG_P8)
    dig_P9 = device.readS16LE(BMP280_REGISTER_DIG_P9)
    #print("dig_T1:",dig_T1," dig_T2:",dig_T2," dig_T3:",dig_T3)
    #print("dig_P1:",dig_P1," dig_P2:",dig_P2," dig_P3:",dig_P3)
    #print(" dig_P4:",dig_P4," dig_P5:",dig_P5," dig_P6:",dig_P6)
    #print(" dig_P7:",dig_P7," dig_P8:",dig_P8," dig_P9:",dig_P9)
    while True: # loop
        raw_temp_msb=device.readU8(BMP280_REGISTER_TEMPDATA_MSB) # read raw temperature msb
        raw_temp_lsb=device.readU8(BMP280_REGISTER_TEMPDATA_LSB) # read raw temperature lsb
        raw_temp_xlsb=device.readU8(BMP280_REGISTER_TEMPDATA_XLSB) # read raw temperature xlsb
        raw_press_msb=device.readU8(BMP280_REGISTER_PRESSDATA_MSB) # read raw pressure msb
        raw_press_lsb=device.readU8(BMP280_REGISTER_PRESSDATA_LSB) # read raw pressure lsb
        raw_press_xlsb=device.readU8(BMP280_REGISTER_PRESSDATA_XLSB) # read raw pressure xlsb
        raw_temp=(raw_temp_msb <<12)+(raw_temp_lsb<<4)+(raw_temp_xlsb>>4) # combine 3 bytes  msb 12 bits left, lsb 4 bits left, xlsb 4 bits right
        raw_press=(raw_press_msb <<12)+(raw_press_lsb <<4)+(raw_press_xlsb >>4) # combine 3 bytes  msb 12 bits left, lsb 4 bits left, xlsb 4 bits right
        # print("raw_press_msb:",raw_press_msb," raw_press_lsb:",raw_press_xlsb," raw_press_xlsb:",raw_press_xlsb)
        # print("raw_temp_msb:",raw_temp_msb,"  raw_temp_lsb:",raw_temp_lsb," raw_temp_xlsb:",raw_temp_xlsb)
        # print("raw_press",raw_press)
        # the following values are from the calculation example in the datasheet
        # this values can be used to check the calculation formulas
        # dig_T1=27504
        # dig_T2=26435
        # dig_T3=-1000
        # dig_P1=36477
        # dig_P2=-10685
        # dig_P3=3024
        # dig_P4=2855
        # dig_P5=140
        # dig_P6=-7
        # dig_P7=15500
        # dig_P8=-14600
        # dig_P9=6000
        # t_fine=128422.2869948
        # raw_temp=519888
        # raw_press=415148
        var1=(raw_temp/16384.0-dig_T1/1024.0)*dig_T2 # formula for temperature from datasheet
        var2=(raw_temp/131072.0-dig_T1/8192.0)*(raw_temp/131072.0-dig_T1/8192.0)*dig_T3 # formula for temperature from datasheet
        temp=(var1+var2)/5120.0 # formula for temperature from datasheet
        t_fine=(var1+var2) # need for pressure calculation
        var1=t_fine/2.0-64000.0 # formula for pressure from datasheet
        var2=var1*var1*dig_P6/32768.0 # formula for pressure from datasheet
        var2=var2+var1*dig_P5*2 # formula for pressure from datasheet
        var2=var2/4.0+dig_P4*65536.0 # formula for pressure from datasheet
        var1=(dig_P3*var1*var1/524288.0+dig_P2*var1)/524288.0 # formula for pressure from datasheet
        var1=(1.0+var1/32768.0)*dig_P1 # formula for pressure from datasheet
        press=1048576.0-raw_press # formula for pressure from datasheet
        press=(press-var2/4096.0)*6250.0/var1 # formula for pressure from datasheet
        var1=dig_P9*press*press/2147483648.0 # formula for pressure from datasheet
        var2=press*dig_P8/32768.0 # formula for pressure from datasheet
        press=press+(var1+var2+dig_P7)/16.0 # formula for pressure from datasheet
        altitude= 44330.0 * (1.0 - pow(press / (QNH*100), (1.0/5.255))) # formula for altitude from airpressure
        print("temperature:{:.2f}".format(temp)+" C  pressure:{:.2f}".format(press/100)+" hPa   altitude:{:.2f}".format(altitude)+" m")
bernd_p
Re: BMP280 with Python
by drewfustini on Tue Feb 02, 2016 11:54 pm
thanks for sharing!
drewfustini
by alg on Thu Feb 11, 2016 7:25 am
This is great.. Just what I was looking for. Thank you so very much!! Amara
alg
by danimath on Sun Feb 21, 2016 5:51 am
Many thanks for sharing! Looking for this since month.
Andreas
danimath
by dcj3616 on Fri Feb 26, 2016 11:51 am
Are you using the Adafruit 2651, or just the Bosch BMP280?
dcj3616
by inexeng on Fri May 13, 2016 7:48 am
Working fine with Adafruit 2651 - on Raspberry Pi
Thank you for sharing
inexeng
by theomcd on Thu Jun 09, 2016 7:16 am
Well that was easy! Up and running on Beagle Bone black in no time. Thank you.
theomcd
by mouha on Thu Sep 29, 2016 11:53 am
Thanks for the share.
Anyway, I have a question with the following values:
temperature:26.55 C pressure:1023.38 hPa altitude:-27.94 m
I'm quite surprised but the altitude result (well I know that I'm not under the sea) it's more possible that this is a sign error, ie: +27 may be something acceptable.
what do you suggest to modify on the altitude formula line please ?
mouha
by Fozed on Fri Sep 30, 2016 11:34 am
I am try to run the script but I become this error as follows, question what I am doing wrong?
pi@Raspbian2:~/BMP280-Python $ sudo python BMP280.py
File "BMP280.py", line 3
IndentationError: unexpected indent
Thank for any help
Fozed
by mouha on Fri Sep 30, 2016 12:36 pm
Fozed wrote:Thanks for the share.
Thank for any help
Python requires that you respect indentations, Check that before the "import" you didn't insert any space.
mouha
by mouha on Sat Oct 01, 2016 7:34 am
bernd_p wrote:Here my solution to get the values from the BMP280 in Python. Adafruit_GPIO is needed.
hi guys,
As the bernd_p code is working fine, I propose to have it in a git repository. Therefore I have created one here : https://framagit.org/dlewin/grove-sensors/tree/master
Anyway, this code will be modified as I intend to use the OOP way, ie : define a dedicated class and methods for the long init part and the usages thereafter.
Aside will be my grove sensors code (wich are using the Adafruit packages) who will be formated the same way.
I intend to put all of them (4 sensors) in a project which could serves as an example.
In addition, I've played (and this is really cool&fun) with Zeromq so your Pi or BeagleBone can be great data provider (kind of fast & reliable data server) by using the PUB/SUB pattern.
Feel free to clone & participate.
mouha
by drewfustini on Mon Oct 03, 2016 11:11 am
Thanks for your efforts.
drewfustini
by mouha on Tue Oct 04, 2016 10:17 am
I have made many changes to define a class that is as much as close as the adafruit implementation, and .... discovered that this work have been already done !
Just do :
Therefore, my repository is not more relevant. Anyway, if anyone is interested in reliable data transmissions (via message queues) I've defined a dedicated project there :
https://framagit.org/dlewin/sensors-data-provider
mouha
by Gimbal on Mon Oct 17, 2016 5:51 pm
Thank you so much for this.
Finally got the sensor working.
Like mouha, I'm getting the -ve value on the altitude (in my case its -16)
Any ideas on the best way to fix this?
where did you get your calculations from for the code?
Just wondering if there may be some slight tweaks that can be made there.
Thanks again.
*EDIT*
I've added an offset of 22 to the altitude calculation and this gives me the correct altitude for my current position.
I'll give it a test tomorrow to see if its still accurate while at work (30 miles away and much further inland)
Gimbal
by drewfustini on Mon Oct 17, 2016 6:53 pm
Gimbal: are you using this fork? https://github.com/bastienwirtz/Adafruit_Python_BMP.git
could you paste the code thay ou are running and the output.
drewfustini
