I have purchased many of your different amplifiers including:
Stereo 2.8W Class D Audio Amplifier - TS2012
Stereo 3.7W Class D Audio Amplifier - MAX98306
Mono 2.5W Class D Audio Amplifier - PAM8302
Stereo 20W Class D Audio Amplifier - MAX9744
I would like to know how I can independently measure the Power that these boards supply to a speaker (ie, a 4-Ohm speaker).
Is there some type of Power meter that can be used? Also can I measure parameters with a standard VOM that will provide the Power value?
In advance, thank you!
- botcabin1
Re: Stereo 2.8W Class D Audio Amplifier - TS2012
There are meters that will measure power, but they tend to be expensive.
In most cases, you just use two meters: one connected to measure the current flowing into the circuit, and one measuring the voltage across the circuit. The product of current and voltage is power.
