I have adapted the Adafruit_BNO055 library so that is uses the i2c_t3 library for I2C instead of Wire. Now, you can use any I2C bus and pins of Teensy with the BNO055 library.
This is my first trip into libraries so any feedback is welcome.
The library is named Adafruit_BNO055_t3.
To use the lib, get i2c_t3 from here and install it.
In your code, type
- Code: Select all | TOGGLE FULL SIZE
#include <i2c_t3.h>
#include <Wire.h>
#include <Adafruit_BNO055_t3.h>
#include <Adafruit_BNO055.h>
Adafruit_BNO055 bno_A = Adafruit_BNO055(55, BNO055_ADDRESS_A);
Adafruit_BNO055 bno = Adafruit_BNO055(WIRE1_BUS, -1, BNO055_ADDRESS_A, I2C_MASTER, I2C_PINS_29_30, I2C_PULLUP_INT, I2C_RATE_100, I2C_OP_MODE_ISR);
This is Adafruit_BNO055_t3.h:
This is a library for the BNO055 orientation sensor
Designed specifically to work with the Adafruit BNO055 Breakout.
Pick one up today in the adafruit shop!
------> http://www.adafruit.com/products
These sensors use I2C to communicate, 2 pins are required to interface.
please support Adafruit andopen-source hardware by purchasing products
from Adafruit!
Written by KTOWN for Adafruit Industries.
!!!!!MODIFIED VERSION TO USE I2C_T3 LIBRARY FOR TEENSY INSTEAD OF WIRE
IN ORDER TO USE TEENSY'S BOTH I2C PORTS
Roald Baudoux - 2016-03
Updated 2016-03-15: i2c_bus type defined to set choice of Wire or Wire1
MIT license, all text above must be included in any redistribution
#ifndef __ADAFRUIT_BNO055_H__
#define __ADAFRUIT_BNO055_H__
#if (ARDUINO >= 100)
#include "Arduino.h"
#else
#include "WProgram.h"
#endif
// code for AT_TINY85 deleted (no AT_TINY85 on Teensy boards)
#include <i2c_t3.h> // MODIFIED FROM Wire.h to i2c_t3.h
#include <Adafruit_Sensor.h>
#include <utility/imumaths.h>
#define BNO055_ADDRESS_A (0x28)
#define BNO055_ADDRESS_B (0x29)
#define BNO055_ID (0xA0)
#define NUM_BNO055_OFFSET_REGISTERS (22)
enum i2c_bus {WIRE_BUS, WIRE1_BUS}; // ADDED RB
typedef struct
uint16_t accel_offset_x;
uint16_t accel_offset_y;
uint16_t accel_offset_z;
uint16_t gyro_offset_x;
uint16_t gyro_offset_y;
uint16_t gyro_offset_z;
uint16_t mag_offset_x;
uint16_t mag_offset_y;
uint16_t mag_offset_z;
uint16_t accel_radius;
uint16_t mag_radius;
} adafruit_bno055_offsets_t;
class Adafruit_BNO055 : public Adafruit_Sensor
public:
typedef enum
/* Page id register definition */
BNO055_PAGE_ID_ADDR = 0X07,
/* PAGE0 REGISTER DEFINITION START*/
BNO055_CHIP_ID_ADDR = 0x00,
BNO055_ACCEL_REV_ID_ADDR = 0x01,
BNO055_MAG_REV_ID_ADDR = 0x02,
BNO055_GYRO_REV_ID_ADDR = 0x03,
BNO055_SW_REV_ID_LSB_ADDR = 0x04,
BNO055_SW_REV_ID_MSB_ADDR = 0x05,
BNO055_BL_REV_ID_ADDR = 0X06,
/* Accel data register */
BNO055_ACCEL_DATA_X_LSB_ADDR = 0X08,
BNO055_ACCEL_DATA_X_MSB_ADDR = 0X09,
BNO055_ACCEL_DATA_Y_LSB_ADDR = 0X0A,
BNO055_ACCEL_DATA_Y_MSB_ADDR = 0X0B,
BNO055_ACCEL_DATA_Z_LSB_ADDR = 0X0C,
BNO055_ACCEL_DATA_Z_MSB_ADDR = 0X0D,
/* Mag data register */
BNO055_MAG_DATA_X_LSB_ADDR = 0X0E,
BNO055_MAG_DATA_X_MSB_ADDR = 0X0F,
BNO055_MAG_DATA_Y_LSB_ADDR = 0X10,
BNO055_MAG_DATA_Y_MSB_ADDR = 0X11,
BNO055_MAG_DATA_Z_LSB_ADDR = 0X12,
BNO055_MAG_DATA_Z_MSB_ADDR = 0X13,
/* Gyro data registers */
BNO055_GYRO_DATA_X_LSB_ADDR = 0X14,
BNO055_GYRO_DATA_X_MSB_ADDR = 0X15,
BNO055_GYRO_DATA_Y_LSB_ADDR = 0X16,
BNO055_GYRO_DATA_Y_MSB_ADDR = 0X17,
BNO055_GYRO_DATA_Z_LSB_ADDR = 0X18,
BNO055_GYRO_DATA_Z_MSB_ADDR = 0X19,
/* Euler data registers */
BNO055_EULER_H_LSB_ADDR = 0X1A,
BNO055_EULER_H_MSB_ADDR = 0X1B,
BNO055_EULER_R_LSB_ADDR = 0X1C,
BNO055_EULER_R_MSB_ADDR = 0X1D,
BNO055_EULER_P_LSB_ADDR = 0X1E,
BNO055_EULER_P_MSB_ADDR = 0X1F,
/* Quaternion data registers */
BNO055_QUATERNION_DATA_W_LSB_ADDR = 0X20,
BNO055_QUATERNION_DATA_W_MSB_ADDR = 0X21,
BNO055_QUATERNION_DATA_X_LSB_ADDR = 0X22,
BNO055_QUATERNION_DATA_X_MSB_ADDR = 0X23,
BNO055_QUATERNION_DATA_Y_LSB_ADDR = 0X24,
BNO055_QUATERNION_DATA_Y_MSB_ADDR = 0X25,
BNO055_QUATERNION_DATA_Z_LSB_ADDR = 0X26,
BNO055_QUATERNION_DATA_Z_MSB_ADDR = 0X27,
/* Linear acceleration data registers */
BNO055_LINEAR_ACCEL_DATA_X_LSB_ADDR = 0X28,
BNO055_LINEAR_ACCEL_DATA_X_MSB_ADDR = 0X29,
BNO055_LINEAR_ACCEL_DATA_Y_LSB_ADDR = 0X2A,
BNO055_LINEAR_ACCEL_DATA_Y_MSB_ADDR = 0X2B,
BNO055_LINEAR_ACCEL_DATA_Z_LSB_ADDR = 0X2C,
BNO055_LINEAR_ACCEL_DATA_Z_MSB_ADDR = 0X2D,
/* Gravity data registers */
BNO055_GRAVITY_DATA_X_LSB_ADDR = 0X2E,
BNO055_GRAVITY_DATA_X_MSB_ADDR = 0X2F,
BNO055_GRAVITY_DATA_Y_LSB_ADDR = 0X30,
BNO055_GRAVITY_DATA_Y_MSB_ADDR = 0X31,
BNO055_GRAVITY_DATA_Z_LSB_ADDR = 0X32,
BNO055_GRAVITY_DATA_Z_MSB_ADDR = 0X33,
/* Temperature data register */
BNO055_TEMP_ADDR = 0X34,
/* Status registers */
BNO055_CALIB_STAT_ADDR = 0X35,
BNO055_SELFTEST_RESULT_ADDR = 0X36,
BNO055_INTR_STAT_ADDR = 0X37,
BNO055_SYS_CLK_STAT_ADDR = 0X38,
BNO055_SYS_STAT_ADDR = 0X39,
BNO055_SYS_ERR_ADDR = 0X3A,
/* Unit selection register */
BNO055_UNIT_SEL_ADDR = 0X3B,
BNO055_DATA_SELECT_ADDR = 0X3C,
/* Mode registers */
BNO055_OPR_MODE_ADDR = 0X3D,
BNO055_PWR_MODE_ADDR = 0X3E,
BNO055_SYS_TRIGGER_ADDR = 0X3F,
BNO055_TEMP_SOURCE_ADDR = 0X40,
/* Axis remap registers */
BNO055_AXIS_MAP_CONFIG_ADDR = 0X41,
BNO055_AXIS_MAP_SIGN_ADDR = 0X42,
/* SIC registers */
BNO055_SIC_MATRIX_0_LSB_ADDR = 0X43,
BNO055_SIC_MATRIX_0_MSB_ADDR = 0X44,
BNO055_SIC_MATRIX_1_LSB_ADDR = 0X45,
BNO055_SIC_MATRIX_1_MSB_ADDR = 0X46,
BNO055_SIC_MATRIX_2_LSB_ADDR = 0X47,
BNO055_SIC_MATRIX_2_MSB_ADDR = 0X48,
BNO055_SIC_MATRIX_3_LSB_ADDR = 0X49,
BNO055_SIC_MATRIX_3_MSB_ADDR = 0X4A,
BNO055_SIC_MATRIX_4_LSB_ADDR = 0X4B,
BNO055_SIC_MATRIX_4_MSB_ADDR = 0X4C,
BNO055_SIC_MATRIX_5_LSB_ADDR = 0X4D,
BNO055_SIC_MATRIX_5_MSB_ADDR = 0X4E,
BNO055_SIC_MATRIX_6_LSB_ADDR = 0X4F,
BNO055_SIC_MATRIX_6_MSB_ADDR = 0X50,
BNO055_SIC_MATRIX_7_LSB_ADDR = 0X51,
BNO055_SIC_MATRIX_7_MSB_ADDR = 0X52,
BNO055_SIC_MATRIX_8_LSB_ADDR = 0X53,
BNO055_SIC_MATRIX_8_MSB_ADDR = 0X54,
/* Accelerometer Offset registers */
ACCEL_OFFSET_X_LSB_ADDR = 0X55,
ACCEL_OFFSET_X_MSB_ADDR = 0X56,
ACCEL_OFFSET_Y_LSB_ADDR = 0X57,
ACCEL_OFFSET_Y_MSB_ADDR = 0X58,
ACCEL_OFFSET_Z_LSB_ADDR = 0X59,
ACCEL_OFFSET_Z_MSB_ADDR = 0X5A,
/* Magnetometer Offset registers */
MAG_OFFSET_X_LSB_ADDR = 0X5B,
MAG_OFFSET_X_MSB_ADDR = 0X5C,
MAG_OFFSET_Y_LSB_ADDR = 0X5D,
MAG_OFFSET_Y_MSB_ADDR = 0X5E,
MAG_OFFSET_Z_LSB_ADDR = 0X5F,
MAG_OFFSET_Z_MSB_ADDR = 0X60,
/* Gyroscope Offset register s*/
GYRO_OFFSET_X_LSB_ADDR = 0X61,
GYRO_OFFSET_X_MSB_ADDR = 0X62,
GYRO_OFFSET_Y_LSB_ADDR = 0X63,
GYRO_OFFSET_Y_MSB_ADDR = 0X64,
GYRO_OFFSET_Z_LSB_ADDR = 0X65,
GYRO_OFFSET_Z_MSB_ADDR = 0X66,
/* Radius registers */
ACCEL_RADIUS_LSB_ADDR = 0X67,
ACCEL_RADIUS_MSB_ADDR = 0X68,
MAG_RADIUS_LSB_ADDR = 0X69,
MAG_RADIUS_MSB_ADDR = 0X6A
} adafruit_bno055_reg_t;
typedef enum
POWER_MODE_NORMAL = 0X00,
POWER_MODE_LOWPOWER = 0X01,
POWER_MODE_SUSPEND = 0X02
} adafruit_bno055_powermode_t;
typedef enum
/* Operation mode settings*/
OPERATION_MODE_CONFIG = 0X00,
OPERATION_MODE_ACCONLY = 0X01,
OPERATION_MODE_MAGONLY = 0X02,
OPERATION_MODE_GYRONLY = 0X03,
OPERATION_MODE_ACCMAG = 0X04,
OPERATION_MODE_ACCGYRO = 0X05,
OPERATION_MODE_MAGGYRO = 0X06,
OPERATION_MODE_AMG = 0X07,
OPERATION_MODE_IMUPLUS = 0X08,
OPERATION_MODE_COMPASS = 0X09,
OPERATION_MODE_M4G = 0X0A,
OPERATION_MODE_NDOF_FMC_OFF = 0X0B,
OPERATION_MODE_NDOF = 0X0C
} adafruit_bno055_opmode_t;
typedef enum
REMAP_CONFIG_P0 = 0x21,
REMAP_CONFIG_P1 = 0x24, // default
REMAP_CONFIG_P2 = 0x24,
REMAP_CONFIG_P3 = 0x21,
REMAP_CONFIG_P4 = 0x24,
REMAP_CONFIG_P5 = 0x21,
REMAP_CONFIG_P6 = 0x21,
REMAP_CONFIG_P7 = 0x24
} adafruit_bno055_axis_remap_config_t;
typedef enum
REMAP_SIGN_P0 = 0x04,
REMAP_SIGN_P1 = 0x00, // default
REMAP_SIGN_P2 = 0x06,
REMAP_SIGN_P3 = 0x02,
REMAP_SIGN_P4 = 0x03,
REMAP_SIGN_P5 = 0x01,
REMAP_SIGN_P6 = 0x07,
REMAP_SIGN_P7 = 0x05
} adafruit_bno055_axis_remap_sign_t;
typedef struct
uint8_t accel_rev;
uint8_t mag_rev;
uint8_t gyro_rev;
uint16_t sw_rev;
uint8_t bl_rev;
} adafruit_bno055_rev_info_t;
typedef enum
VECTOR_ACCELEROMETER = BNO055_ACCEL_DATA_X_LSB_ADDR,
VECTOR_MAGNETOMETER = BNO055_MAG_DATA_X_LSB_ADDR,
VECTOR_GYROSCOPE = BNO055_GYRO_DATA_X_LSB_ADDR,
VECTOR_EULER = BNO055_EULER_H_LSB_ADDR,
VECTOR_LINEARACCEL = BNO055_LINEAR_ACCEL_DATA_X_LSB_ADDR,
VECTOR_GRAVITY = BNO055_GRAVITY_DATA_X_LSB_ADDR
} adafruit_vector_type_t;
// Arduino Zero board check removed (No Zero in Teensy range)
#ifdef ARDUINO_SAMD_ZERO
#error "On an arduino Zero, BNO055's ADR pin must be high. Fix that, then delete this line."
Adafruit_BNO055 ( int32_t sensorID = -1, uint8_t address = BNO055_ADDRESS_B );
#else
Adafruit_BNO055 ( int32_t sensorID = -1, uint8_t address = BNO055_ADDRESS_A );
#endif
Adafruit_BNO055 (i2c_bus iBus = WIRE_BUS, int32_t sensorID = -1, uint8_t aAddress = BNO055_ADDRESS_A, i2c_mode iMode = I2C_MASTER, i2c_pins pins = I2C_PINS_18_19, i2c_pullup pullup = I2C_PULLUP_INT, i2c_rate iRate = I2C_RATE_100, i2c_op_mode opeMode = I2C_OP_MODE_ISR); // MODIFIED
bool begin ( adafruit_bno055_opmode_t aMode = OPERATION_MODE_NDOF );
void setMode ( adafruit_bno055_opmode_t aMode );
void getRevInfo ( adafruit_bno055_rev_info_t* );
void displayRevInfo ( void );
void setExtCrystalUse ( boolean usextal );
void getSystemStatus ( uint8_t *system_status,
uint8_t *self_test_result,
uint8_t *system_error);
void displaySystemStatus ( void );
void getCalibration ( uint8_t* system, uint8_t* gyro, uint8_t* accel, uint8_t* mag);
imu::Vector<3> getVector ( adafruit_vector_type_t vector_type );
imu::Quaternion getQuat ( void );
int8_t getTemp ( void );
/* Adafruit_Sensor implementation */
bool getEvent ( sensors_event_t* );
void getSensor ( sensor_t* );
/* Functions to deal with raw calibration data */
bool getSensorOffsets(uint8_t* calibData);
bool getSensorOffsets(adafruit_bno055_offsets_t &offsets_type);
void setSensorOffsets(const uint8_t* calibData);
void setSensorOffsets(const adafruit_bno055_offsets_t &offsets_type);
bool isFullyCalibrated(void);
private:
byte read8 ( adafruit_bno055_reg_t );
bool readLen ( adafruit_bno055_reg_t, byte* buffer, uint8_t len );
bool write8 ( adafruit_bno055_reg_t, byte value );
// bool _i2cBus; // ADDED : O for Wire and 1 for Wire1
uint8_t _aAddress;
int32_t _sensorID;
adafruit_bno055_opmode_t _aMode;
// ADDED RB :
i2c_bus _iBus; // Wire or Wire 1
i2c_mode _iMode; // MASTER OR SLAVE MODE
i2c_pins _pins;
i2c_pullup _pullup;
i2c_rate _iRate;
i2c_op_mode _opeMode;
#endif
from Adafruit!
#if ARDUINO >= 100
#else
#endif
#include <math.h>
#include <limits.h>
#include "Adafruit_BNO055_t3.h" // MODIFIED RB
CONSTRUCTOR
@brief Instantiates a new Adafruit_BNO055 class
!!!!! MODIFIED TO BE COMPATIBLE WITH I2C_T3 library instead of Wire
// Params : I2C bus, sensor ID, address, I2C mode (master/slave), pins, pullups, freq, opMode (interrupt/DMA/immediate)
// OLD : Adafruit_BNO055::Adafruit_BNO055(int32_t sensorID, uint8_t address)
Adafruit_BNO055::Adafruit_BNO055(i2c_bus iBus, int32_t sensorID, uint8_t aAddress, i2c_mode iMode, i2c_pins pins, i2c_pullup pullup, i2c_rate iRate, i2c_op_mode opeMode)
_iBus = iBus; // ADDED RB 0 for Wire() and 1 for Wire1();
_sensorID = sensorID;
_aAddress = aAddress;
_iMode = iMode; // ADDED RB
_pins = pins; // ADDED RB
_pullup = pullup; // ADDED RB
_iRate = iRate; // ADDED RB
_opeMode = opeMode; // ADDED RB
PUBLIC FUNCTIONS
@brief Sets up the HW
bool Adafruit_BNO055::begin(adafruit_bno055_opmode_t aMode)
/* Enable I2C */
if (_iBus == WIRE_BUS)
Wire.begin(_iMode, _aAddress, _pins, _pullup, _iRate, _opeMode);
else
Wire1.begin(_iMode, _aAddress, _pins, _pullup, _iRate, _opeMode);
/* Make sure we have the right device */
uint8_t id = read8(BNO055_CHIP_ID_ADDR);
if(id != BNO055_ID)
delay(1000); // hold on for boot
if(id != BNO055_ID) {
return false; // still not? ok bail
/* Switch to config mode (just in case since this is the default) */
setMode(OPERATION_MODE_CONFIG);
/* Reset */
write8(BNO055_SYS_TRIGGER_ADDR, 0x20);
while (read8(BNO055_CHIP_ID_ADDR) != BNO055_ID)
delay(10);
delay(50);
/* Set to normal power mode */
write8(BNO055_PWR_MODE_ADDR, POWER_MODE_NORMAL);
delay(10);
write8(BNO055_PAGE_ID_ADDR, 0);
/* Set the output units */
uint8_t unitsel = (0 << 7) | // Orientation = Android
(0 << 4) | // Temperature = Celsius
(0 << 2) | // Euler = Degrees
(1 << 1) | // Gyro = Rads
(0 << 0); // Accelerometer = m/s^2
write8(BNO055_UNIT_SEL_ADDR, unitsel);
/* Configure axis mapping (see section 3.4) */
write8(BNO055_AXIS_MAP_CONFIG_ADDR, REMAP_CONFIG_P2); // P0-P7, Default is P1
delay(10);
write8(BNO055_AXIS_MAP_SIGN_ADDR, REMAP_SIGN_P2); // P0-P7, Default is P1
delay(10);
write8(BNO055_SYS_TRIGGER_ADDR, 0x0);
delay(10);
/* Set the requested operating mode (see section 3.3) */
setMode(aMode);
delay(20);
return true;
@brief Puts the chip in the specified operating mode
void Adafruit_BNO055::setMode(adafruit_bno055_opmode_t aMode)
_aMode = aMode;
write8(BNO055_OPR_MODE_ADDR, _aMode);
delay(30);
@brief Use the external 32.768KHz crystal
void Adafruit_BNO055::setExtCrystalUse(boolean usextal)
adafruit_bno055_opmode_t modeback = _aMode;
delay(25);
if (usextal) {
write8(BNO055_SYS_TRIGGER_ADDR, 0x80);
} else {
write8(BNO055_SYS_TRIGGER_ADDR, 0x00);
delay(10);
setMode(modeback);
delay(20);
@brief Gets the latest system status info
void Adafruit_BNO055::getSystemStatus(uint8_t *system_status, uint8_t *self_test_result, uint8_t *system_error)
/* System Status (see section 4.3.58)
0 = Idle
1 = System Error
2 = Initializing Peripherals
3 = System Iniitalization
4 = Executing Self-Test
5 = Sensor fusio algorithm running
6 = System running without fusion algorithms */
if (system_status != 0)
*system_status = read8(BNO055_SYS_STAT_ADDR);
/* Self Test Results (see section )
1 = test passed, 0 = test failed
Bit 0 = Accelerometer self test
Bit 1 = Magnetometer self test
Bit 2 = Gyroscope self test
Bit 3 = MCU self test
0x0F = all good! */
if (self_test_result != 0)
*self_test_result = read8(BNO055_SELFTEST_RESULT_ADDR);
/* System Error (see section 4.3.59)
0 = No error
1 = Peripheral initialization error
2 = System initialization error
3 = Self test result failed
4 = Register map value out of range
5 = Register map address out of range
6 = Register map write error
7 = BNO low power mode not available for selected operat ion mode
8 = Accelerometer power mode not available
9 = Fusion algorithm configuration error
A = Sensor configuration error */
if (system_error != 0)
*system_error = read8(BNO055_SYS_ERR_ADDR);
delay(200);
@brief Gets the chip revision numbers
void Adafruit_BNO055::getRevInfo(adafruit_bno055_rev_info_t* info)
uint8_t a, b;
memset(info, 0, sizeof(adafruit_bno055_rev_info_t));
/* Check the accelerometer revision */
info->accel_rev = read8(BNO055_ACCEL_REV_ID_ADDR);
/* Check the magnetometer revision */
info->mag_rev = read8(BNO055_MAG_REV_ID_ADDR);
/* Check the gyroscope revision */
info->gyro_rev = read8(BNO055_GYRO_REV_ID_ADDR);
/* Check the SW revision */
info->bl_rev = read8(BNO055_BL_REV_ID_ADDR);
a = read8(BNO055_SW_REV_ID_LSB_ADDR);
b = read8(BNO055_SW_REV_ID_MSB_ADDR);
info->sw_rev = (((uint16_t)b) << 8) | ((uint16_t)a);
@brief Gets current calibration state. Each value should be a uint8_t
pointer and it will be set to 0 if not calibrated and 3 if
fully calibrated.
void Adafruit_BNO055::getCalibration(uint8_t* sys, uint8_t* gyro, uint8_t* accel, uint8_t* mag) {
uint8_t calData = read8(BNO055_CALIB_STAT_ADDR);
if (sys != NULL) {
*sys = (calData >> 6) & 0x03;
if (gyro != NULL) {
*gyro = (calData >> 4) & 0x03;
if (accel != NULL) {
*accel = (calData >> 2) & 0x03;
if (mag != NULL) {
*mag = calData & 0x03;
@brief Gets the temperature in degrees celsius
int8_t Adafruit_BNO055::getTemp(void)
int8_t temp = (int8_t)(read8(BNO055_TEMP_ADDR));
return temp;
@brief Gets a vector reading from the specified source
imu::Vector<3> Adafruit_BNO055::getVector(adafruit_vector_type_t vector_type)
imu::Vector<3> xyz;
uint8_t buffer[6];
memset (buffer, 0, 6);
int16_t x, y, z;
x = y = z = 0;
/* Read vector data (6 bytes) */
readLen((adafruit_bno055_reg_t)vector_type, buffer, 6);
x = ((int16_t)buffer[0]) | (((int16_t)buffer[1]) << 8);
y = ((int16_t)buffer[2]) | (((int16_t)buffer[3]) << 8);
z = ((int16_t)buffer[4]) | (((int16_t)buffer[5]) << 8);
/* Convert the value to an appropriate range (section 3.6.4) */
/* and assign the value to the Vector type */
switch(vector_type)
case VECTOR_MAGNETOMETER:
/* 1uT = 16 LSB */
xyz[0] = ((double)x)/16.0;
xyz[1] = ((double)y)/16.0;
xyz[2] = ((double)z)/16.0;
break;
case VECTOR_GYROSCOPE:
/* 1rps = 900 LSB */
xyz[0] = ((double)x)/900.0;
xyz[1] = ((double)y)/900.0;
xyz[2] = ((double)z)/900.0;
break;
case VECTOR_EULER:
/* 1 degree = 16 LSB */
break;
case VECTOR_ACCELEROMETER:
case VECTOR_LINEARACCEL:
case VECTOR_GRAVITY:
/* 1m/s^2 = 100 LSB */
xyz[0] = ((double)x)/100.0;
xyz[1] = ((double)y)/100.0;
xyz[2] = ((double)z)/100.0;
break;
return xyz;
@brief Gets a quaternion reading from the specified source
imu::Quaternion Adafruit_BNO055::getQuat(void)
uint8_t buffer[8];
memset (buffer, 0, 8);
int16_t x, y, z, w;
x = y = z = w = 0;
/* Read quat data (8 bytes) */
readLen(BNO055_QUATERNION_DATA_W_LSB_ADDR, buffer, 8);
w = (((uint16_t)buffer[1]) << 8) | ((uint16_t)buffer[0]);
x = (((uint16_t)buffer[3]) << 8) | ((uint16_t)buffer[2]);
y = (((uint16_t)buffer[5]) << 8) | ((uint16_t)buffer[4]);
z = (((uint16_t)buffer[7]) << 8) | ((uint16_t)buffer[6]);
/* Assign to Quaternion */
/* See http://ae-bst.resource.bosch.com/media/products/dokumente/bno055/BST_BNO055_DS000_12~1.pdf
3.6.5.5 Orientation (Quaternion) */
const double scale = (1.0 / (1<<14));
imu::Quaternion quat(scale * w, scale * x, scale * y, scale * z);
return quat;
@brief Provides the sensor_t data for this sensor
void Adafruit_BNO055::getSensor(sensor_t *sensor)
/* Clear the sensor_t object */
memset(sensor, 0, sizeof(sensor_t));
/* Insert the sensor name in the fixed length char array */
strncpy (sensor->name, "BNO055", sizeof(sensor->name) - 1);
sensor->name[sizeof(sensor->name)- 1] = 0;
sensor->version = 1;
sensor->sensor_id = _sensorID;
sensor->type = SENSOR_TYPE_ORIENTATION;
sensor->min_delay = 0;
sensor->max_value = 0.0F;
sensor->min_value = 0.0F;
sensor->resolution = 0.01F;
@brief Reads the sensor and returns the data as a sensors_event_t
bool Adafruit_BNO055::getEvent(sensors_event_t *event)
/* Clear the event */
memset(event, 0, sizeof(sensors_event_t));
event->version = sizeof(sensors_event_t);
event->sensor_id = _sensorID;
event->type = SENSOR_TYPE_ORIENTATION;
event->timestamp = millis();
/* Get a Euler angle sample for orientation */
imu::Vector<3> euler = getVector(Adafruit_BNO055::VECTOR_EULER);
event->orientation.x = euler.x();
event->orientation.y = euler.y();
event->orientation.z = euler.z();
return true;
@brief Reads the sensor's offset registers into a byte array
bool Adafruit_BNO055::getSensorOffsets(uint8_t* calibData)
if (isFullyCalibrated())
adafruit_bno055_opmode_t lastMode = _aMode;
readLen(ACCEL_OFFSET_X_LSB_ADDR, calibData, NUM_BNO055_OFFSET_REGISTERS);
setMode(lastMode);
return true;
return false;
@brief Reads the sensor's offset registers into an offset struct
bool Adafruit_BNO055::getSensorOffsets(adafruit_bno055_offsets_t &offsets_type)
delay(25);
offsets_type.accel_offset_x = (read8(ACCEL_OFFSET_X_MSB_ADDR) << 8) | (read8(ACCEL_OFFSET_X_LSB_ADDR));
offsets_type.accel_offset_y = (read8(ACCEL_OFFSET_Y_MSB_ADDR) << 8) | (read8(ACCEL_OFFSET_Y_LSB_ADDR));
offsets_type.accel_offset_z = (read8(ACCEL_OFFSET_Z_MSB_ADDR) << 8) | (read8(ACCEL_OFFSET_Z_LSB_ADDR));
offsets_type.gyro_offset_x = (read8(GYRO_OFFSET_X_MSB_ADDR) << 8) | (read8(GYRO_OFFSET_X_LSB_ADDR));
offsets_type.gyro_offset_y = (read8(GYRO_OFFSET_Y_MSB_ADDR) << 8) | (read8(GYRO_OFFSET_Y_LSB_ADDR));
offsets_type.gyro_offset_z = (read8(GYRO_OFFSET_Z_MSB_ADDR) << 8) | (read8(GYRO_OFFSET_Z_LSB_ADDR));
offsets_type.mag_offset_x = (read8(MAG_OFFSET_X_MSB_ADDR) << 8) | (read8(MAG_OFFSET_X_LSB_ADDR));
offsets_type.mag_offset_y = (read8(MAG_OFFSET_Y_MSB_ADDR) << 8) | (read8(MAG_OFFSET_Y_LSB_ADDR));
offsets_type.mag_offset_z = (read8(MAG_OFFSET_Z_MSB_ADDR) << 8) | (read8(MAG_OFFSET_Z_LSB_ADDR));
offsets_type.accel_radius = (read8(ACCEL_RADIUS_MSB_ADDR) << 8) | (read8(ACCEL_RADIUS_LSB_ADDR));
offsets_type.mag_radius = (read8(MAG_RADIUS_MSB_ADDR) << 8) | (read8(MAG_RADIUS_LSB_ADDR));
setMode(lastMode);
return true;
return false;
@brief Writes an array of calibration values to the sensor's offset registers
void Adafruit_BNO055::setSensorOffsets(const uint8_t* calibData)
delay(25);
/* A writeLen() would make this much cleaner */
write8(ACCEL_OFFSET_X_LSB_ADDR, calibData[0]);
write8(ACCEL_OFFSET_X_MSB_ADDR, calibData[1]);
write8(ACCEL_OFFSET_Y_LSB_ADDR, calibData[2]);
write8(ACCEL_OFFSET_Y_MSB_ADDR, calibData[3]);
write8(ACCEL_OFFSET_Z_LSB_ADDR, calibData[4]);
write8(ACCEL_OFFSET_Z_MSB_ADDR, calibData[5]);
write8(GYRO_OFFSET_X_LSB_ADDR, calibData[6]);
write8(GYRO_OFFSET_X_MSB_ADDR, calibData[7]);
write8(GYRO_OFFSET_Y_LSB_ADDR, calibData[8]);
write8(GYRO_OFFSET_Y_MSB_ADDR, calibData[9]);
write8(GYRO_OFFSET_Z_LSB_ADDR, calibData[10]);
write8(GYRO_OFFSET_Z_MSB_ADDR, calibData[11]);
write8(MAG_OFFSET_X_LSB_ADDR, calibData[12]);
write8(MAG_OFFSET_X_MSB_ADDR, calibData[13]);
write8(MAG_OFFSET_Y_LSB_ADDR, calibData[14]);
write8(MAG_OFFSET_Y_MSB_ADDR, calibData[15]);
write8(MAG_OFFSET_Z_LSB_ADDR, calibData[16]);
write8(MAG_OFFSET_Z_MSB_ADDR, calibData[17]);
write8(ACCEL_RADIUS_LSB_ADDR, calibData[18]);
write8(ACCEL_RADIUS_MSB_ADDR, calibData[19]);
write8(MAG_RADIUS_LSB_ADDR, calibData[20]);
write8(MAG_RADIUS_MSB_ADDR, calibData[21]);
setMode(lastMode);
@brief Writes to the sensor's offset registers from an offset struct
void Adafruit_BNO055::setSensorOffsets(const adafruit_bno055_offsets_t &offsets_type)
delay(25);
write8(ACCEL_OFFSET_X_LSB_ADDR, (offsets_type.accel_offset_x) & 0x0FF);
write8(ACCEL_OFFSET_X_MSB_ADDR, (offsets_type.accel_offset_x >> 8) & 0x0FF);
write8(ACCEL_OFFSET_Y_LSB_ADDR, (offsets_type.accel_offset_y) & 0x0FF);
write8(ACCEL_OFFSET_Y_MSB_ADDR, (offsets_type.accel_offset_y >> 8) & 0x0FF);
write8(ACCEL_OFFSET_Z_LSB_ADDR, (offsets_type.accel_offset_z) & 0x0FF);
write8(ACCEL_OFFSET_Z_MSB_ADDR, (offsets_type.accel_offset_z >> 8) & 0x0FF);
write8(GYRO_OFFSET_X_LSB_ADDR, (offsets_type.gyro_offset_x) & 0x0FF);
write8(GYRO_OFFSET_X_MSB_ADDR, (offsets_type.gyro_offset_x >> 8) & 0x0FF);
write8(GYRO_OFFSET_Y_LSB_ADDR, (offsets_type.gyro_offset_y) & 0x0FF);
write8(GYRO_OFFSET_Y_MSB_ADDR, (offsets_type.gyro_offset_y >> 8) & 0x0FF);
write8(GYRO_OFFSET_Z_LSB_ADDR, (offsets_type.gyro_offset_z) & 0x0FF);
write8(GYRO_OFFSET_Z_MSB_ADDR, (offsets_type.gyro_offset_z >> 8) & 0x0FF);
write8(MAG_OFFSET_X_LSB_ADDR, (offsets_type.mag_offset_x) & 0x0FF);
write8(MAG_OFFSET_X_MSB_ADDR, (offsets_type.mag_offset_x >> 8) & 0x0FF);
write8(MAG_OFFSET_Y_LSB_ADDR, (offsets_type.mag_offset_y) & 0x0FF);
write8(MAG_OFFSET_Y_MSB_ADDR, (offsets_type.mag_offset_y >> 8) & 0x0FF);
write8(MAG_OFFSET_Z_LSB_ADDR, (offsets_type.mag_offset_z) & 0x0FF);
write8(MAG_OFFSET_Z_MSB_ADDR, (offsets_type.mag_offset_z >> 8) & 0x0FF);
write8(ACCEL_RADIUS_LSB_ADDR, (offsets_type.accel_radius) & 0x0FF);
write8(ACCEL_RADIUS_MSB_ADDR, (offsets_type.accel_radius >> 8) & 0x0FF);
write8(MAG_RADIUS_LSB_ADDR, (offsets_type.mag_radius) & 0x0FF);
write8(MAG_RADIUS_MSB_ADDR, (offsets_type.mag_radius >> 8) & 0x0FF);
setMode(lastMode);
bool Adafruit_BNO055::isFullyCalibrated(void)
uint8_t system, gyro, accel, mag;
getCalibration(&system, &gyro, &accel, &mag);
if (system < 3 || gyro < 3 || accel < 3 || mag < 3)
return false;
return true;
PRIVATE FUNCTIONS
@brief Writes an 8 bit value over I2C
bool Adafruit_BNO055::write8(adafruit_bno055_reg_t reg, byte value)
Wire.beginTransmission(_aAddress); //// MODIFIED RB
#if ARDUINO >= 100
Wire.write((uint8_t)reg); /// TO BE MODIFIED? NO
Wire.write((uint8_t)value); /// TO BE MODIFIED? NO
#else
Wire.send(reg); /// TO BE MODIFIED? NO
Wire.send(value); /// TO BE MODIFIED? NO
#endif
Wire.endTransmission(); /// TO BE MODIFIED? NO
/* ToDo: Check for error! */
return true;
else
Wire1.beginTransmission(_aAddress); //// MODIFIED RB
#if ARDUINO >= 100
Wire1.write((uint8_t)reg); /// TO BE MODIFIED? NO
Wire1.write((uint8_t)value); /// TO BE MODIFIED? NO
#else
Wire1.send(reg); /// TO BE MODIFIED? NO
Wire1.send(value); /// TO BE MODIFIED? NO
#endif
Wire1.endTransmission(); /// TO BE MODIFIED? NO
return true;
@brief Reads an 8 bit value over I2C
byte Adafruit_BNO055::read8(adafruit_bno055_reg_t reg )
byte value = 0;
Wire.beginTransmission(_aAddress); /// TO BE MODIFIED? NO
#if ARDUINO >= 100
#else
Wire.send(reg);
#endif
Wire.requestFrom(_aAddress, (byte)1); /// TO BE MODIFIED? NO
#if ARDUINO >= 100
value = Wire.read(); /// TO BE MODIFIED? NO
#else
value = Wire.readByte(); //// MODIFIED RB receive -> readByte
#endif
return value;
else
Wire1.beginTransmission(_aAddress); /// TO BE MODIFIED? NO
#if ARDUINO >= 100
#else
Wire1.send(reg);
#endif
Wire1.requestFrom(_aAddress, (byte)1); /// TO BE MODIFIED? NO
#if ARDUINO >= 100
value = Wire1.read(); /// TO BE MODIFIED? NO
#else
value = Wire1.readByte(); //// MODIFIED RB receive -> readByte
#endif
return value;
@brief Reads the specified number of bytes over I2C
bool Adafruit_BNO055::readLen(adafruit_bno055_reg_t reg, byte * buffer, uint8_t len)
#if ARDUINO >= 100
#else
#endif
Wire.requestFrom(_aAddress, (byte)len); /// TO BE MODIFIED? NO
for (uint8_t i = 0; i < len; i++)
#if ARDUINO >= 100
buffer[i] = Wire.read(); /// TO BE MODIFIED? NO
#else
buffer[i] = Wire.readByte(); //// MODIFIE RB receive -> readByte
#endif
/* ToDo: Check for errors! */
return true;
else
#if ARDUINO >= 100
#else
#endif
Wire1.requestFrom(_aAddress, (byte)len); /// TO BE MODIFIED? NO
#if ARDUINO >= 100
buffer[i] = Wire1.read(); /// TO BE MODIFIED? NO
#else
buffer[i] = Wire1.readByte(); //// MODIFIE RB receive -> readByte
#endif
return true;
I hope this code is useful.
EDIT : please note that an updated version of Adafruit_BNO055_t3_V2.cpp is provided in a later post within this thread.
