I'm following the tutorial on setting up the DS1307. I get as far as the Raspbian Jessie (Systemd) section. I ran sudo nano /etc/conf.d/rtc-i2c, did the edits but get an
"error writing /etc/conf.d/rtc-i2c: No such file or directory" when I do a ctrl X and try to save the file?
https://learn.adafruit.com/adding-a-rea ... t-rtc-time
What am I missing?
DS1307 RTC breakout bord, error writting /etc/conf.d/rtc-i2c
- alphanumeric
Re: DS1307 RTC breakout bord, error writting /etc/conf.d/rtc
It may be a permissions problem. Try using `sudo nano /etc/conf.d/rtc-i2c`
- alphanumeric
I ran "sudo nano /etc/conf.d/rtc-i2c" as per the tutorial. Should I maybe run sudo bash, then that command?
Quick tip for swapping to a root shell: the command `sudo su -` will make the system act like you've logged in as root. When you type `exit`, you'll drop back to the user account.
Let's double-check something first though: what output do you get from:
ls -l /etc
- alphanumeric
Running ls -l /etc gets me a long list on the screen, with some in blue text. I see a cron.d but no cronf.d
Running sudo su or sudo bash makes no difference. I still get the no such file or directory when I try to save the file.
I need to see the actual output from the command to see what the problem is.
- alphanumeric
Ok, I'll fire it up and remote in, then clip and past it back to this thread. It will be a few hours from now before I have time to do it. Other things on the go right now.
- alphanumeric
I clipped the output and put it in code tags but it won't let me post it. "Your post contains banned spam words". I have no idea what to edit out? I can't see anything marked or identified?
- alphanumeric
I had to edit out an r m t and replace it with >>>
pi@raspberrypi:~ $ ls -1 /etc
adduser.conf
adjtime
alternatives
apache2
apm
BANNED.d
apt
avahi
bash.bashrc
bash_completion
bash_completion.d
bindresvport.blacklist
binfmt.d
bluetooth
ca-certificates
ca-certificates.conf
calendar
console-setup
cron.d
cron.daily
cron.hourly
cron.monthly
crontab
cron.weekly
dbus-1
debconf.conf
debian_version
default
deluser.conf
dhcp
dhcp3
dhcpcd.conf
dhcpcd.duid
dictionaries-common
dillo
dphys-swapfile
dpkg
drirc
emacs
environment
esound
fake-hwclock.data
fb.modes
fonts
fstab
fuse.conf
gai.conf
gconf
gdb
ghostscript
gnome
groff
group
group-
gshadow
gshadow-
gss
gtk-2.0
gtk-3.0
hdparm.conf
host.conf
hostname
hosts
hosts.allow
hosts.deny
idmapd.conf
ifplugd
init
init.d
initramfs-tools
inputrc
insserv
insserv.conf
insserv.conf.d
iproute2
issue
issue.net
kbd
kernel
ldap
ld.so.cache
ld.so.conf
ld.so.conf.d
ld.so.preload
libaudit.conf
libnl-3
libreoffice
lightdm
lighttpd
locale.alias
locale.gen
localtime
logcheck
login.defs
logrotate.conf
logrotate.d
machine-id
magic
magic.mime
mailcap
mailcap.order
manpath.config
menu-methods
mime.types
mke2fs.conf
modprobe.d
modules
modules-load.d
motd
mtab
nanorc
netconfig
network
networks
newt
nsswitch.conf
ntp.conf
openal
opt
os-release
PackageKit
pam.conf
pam.d
passwd
passwd-
perl
plymouth
polkit-1
ppp
profile
profile.d
protocols
pulse
python
python2.7
python3
python3.4
rc0.d
rc1.d
rc2.d
rc3.d
rc4.d
rc5.d
rc6.d
rc.local
rcS.d
request-key.d
resolvconf
resolv.conf
resolvconf.conf
rpc
rpi-issue
rsyslog.conf
rsyslog.d
RTIMULib.ini
samba
securetty
security
selinux
services
sgml
shadow
shadow-
shells
skel
ssh
ssl
staff-group-for-usr-local
subgid
subgid-
subuid
subuid-
sudoers
sudoers.d
sysctl.conf
sysctl.d
systemd
terminfo
timezone
timidity
tmpfiles.d
triggerhappy
ucf.conf
udev
udisks2
ufw
usb_modeswitch.conf
usb_modeswitch.d
vdpau_wrapper.cfg
vim
wgetrc
wildmidi
wpa_supplicant
X11
xdg
xml
xpdf
xrdp
pi@raspberrypi:~ $
Thank you. The problem is that you don't have a directory named /etc/conf.d
Do this:
Do this:
sudo mkdir /etc/conf.d
- alphanumeric
Ok, that's what I was thinking too. last night I did a
And was able to save the file with no error message.
sudo -i
cd /etc
mkdir conf.d
Good to hear. Happy hacking!
- alphanumeric
Still doesn't work though. My Pi loses time when powered down. Battery is good. sudo hwclock -r doesn't work now either. I can't read or write the time to from the DS1307. It worked initially, I set it to the correct time in the beginning of the tutorial. I forget what the message was at the moment. I believe the "disable the fake hwclock" part at the end is what did this?
Do you have a battery connected to the DS1307? It needs one to keep time while the RasPi is shut down.
- alphanumeric
Yes, as I said above, Battery is good. I checked it with my battery tester. Polarity is correct too, double checked that to make sure it was in the correct way and not upside down.
