trinket 5v avrdude error usbtiny_received (expected 4, got -
by hyp3rMC on Fri Aug 11, 2017 8:17 am
Hi there,
I need some help in uploading code to the trinket 5v. I have tried it with arduino IDE but it keeps giving me this message.
I check with avrdude and it reads the trinket ok from what I can tell...
I can't seem to upload anything on the trinket 5v weather I run on 8 or 16MHz. I have followed through with the learning guide as well as updated avrdude.conf from the guide. trinket green light is on and stable. I press reset as before uploading and the red light blinks as the guide indicates. Here are the settings on my tools in arduino IDE;
I'm at my wits end so if you can please shed a light on this, I would really appreciate it.
Thank you!
hyp3rMC
Re: trinket 5v avrdude error usbtiny_received (expected 4, g
by hyp3rMC on Fri Aug 11, 2017 8:44 am
I just want to give an update...
uploading a sample hex file from the guide was successful via avrdude. I was able to upload the blink sketch via avrdude with this command: avrdude -c usbtiny -p attiny85 -D -U flash:w:trinketblink.hex
Arduino IDE is still no go...
hyp3rMC
by adafruit_support_rick on Fri Aug 11, 2017 8:45 am
That error code simply indicates a retry. Does the sketch work after the upload completes?
by hyp3rMC on Fri Aug 11, 2017 10:28 am
Thank you for the quick reply. No the sketch doesn't work at all.
hyp3rMC
by adafruit_support_rick on Fri Aug 11, 2017 12:24 pm
Go into Arduino Preferences and check off the box for verbose on upload.
Post the entire upload trace here
by hyp3rMC on Fri Aug 11, 2017 12:34 pm
Thank you very much Rick. I will do that tonight once I get home. I will continue to try the upload and will post the output here later. I appreciate it.
hyp3rMC
