🎁📬❄️📦 Holiday Shipping Deadlines are approaching! International customers and domestic ground - get your orders in 12/9/2020 📦❄️📬🎁
FTDI Serial TTL-232 USB Cable
by sekramer10 on Sat Oct 01, 2016 2:36 am
I got the FTDI Serial TTL-232 USB Cable and I was wondering can I use this to read serial print statement data from an ATtiny85 running SoftwareSerial and see the data on the serial monitor in the Arduino IDE or on PuTTY? I tried to read it with PuTTY but didn't get anything.
Thanks,
Stephen
sekramer10
Re: FTDI Serial TTL-232 USB Cable
by franklin97355 on Sat Oct 01, 2016 12:48 pm
How are you connecting the 85 to the cable?
franklin97355
by sekramer10 on Sat Oct 01, 2016 1:16 pm
Through short jumper wires. I tried connecting the data lines and ground only, and also tried to power the whole chip by connecting VCC as well. This is the first time I have used PuTTY but I think I have it set up right, do you know if there's anything specific I need to do there to use the cable?
sekramer10
by franklin97355 on Sat Oct 01, 2016 1:21 pm
Make sure you are connecting rx of the cable to tx of the chip and tx of the cable to rx of the chip. Could you post a picture of your setup?
franklin97355
