Gemma's are not working
by ccrump on Tue Oct 11, 2016 7:42 pm
I am also having a problem with Gemma's I recently purchased, when I emailed support they stated I need to go to the forum first. When I saw that someone else posted having the same exact issue I wrote them about.
It's seems more likely that their is a bad batch of Gemma's released or the bootloader is not stable.
I purchased mine via Amazon Prime order# 105-5803404-4966624
I have a MAC, OS X 10.11.5
Arduino IDE 1.6.5
Adafruit AVR ver 1.4.9
receive the following error each time I attempt to upload your example sketches. I have not attached anything to the Gemma's other than the USB cable. (I did this because when this occured in April I was informed that I may have damaged them.)
avrdude: Error: Could not find USBtiny device (0x1781/0xc9f)
I do not have a problem uploading sketches to my ProTrinket or other Arduino based devices using the same cable(s). I can only determine there must be an issue with the Gemma's.
Sincerely,
Chris
ccrump
Re: Gemma's are not working
by adafruit_support_rick on Thu Oct 13, 2016 8:13 am
What does the red LED do when you press reset?
Look in the MacOSX System Report. Does the Gemma appear there? (as a Trinket)
