Writing | avrdude: error: usbtiny_
Re: Writing | avrdude: error: usbtiny_
by ghh on Thu Oct 27, 2016 11:46 pm
still getting error can't find USBtiny device.
Arduino: 1.6.12 (Mac OS X), Board: "Arduino Gemma"
Sketch uses 692 bytes (13%) of program storage space. Maximum is 5,310 bytes.
Global variables use 9 bytes of dynamic memory.
avrdude: Error: Could not find USBtiny device (0x2341/0xc9f)
ghh
by ghh on Fri Oct 28, 2016 12:17 am
just tried from my PC laptop (instead of my iMac). And got this error
Arduino: 1.6.12 (Windows 8.1), Board: "Arduino Gemma"
avrdude: error: usbtiny_transmit:
avrdude: initialization failed, rc=-1
this check.
ghh
by adafruit_support_rick on Fri Oct 28, 2016 9:24 am
This is with a hub and new cable? Is the red LED still blinking when you press reset? Or does it fade in and out? Are you pressing reset just before the upload begins?
by ghh on Fri Oct 28, 2016 9:34 am
I did not get a hub but got a new cable. The light fades in and out not blinking. I hit the reset button after I verify the code and then wait for the red light to stop pulsing. Then I upload the code and I get the same error. I've tried turning the gemma on and off. Unplugging and replugging it in.
ghh
by adafruit_support_rick on Fri Oct 28, 2016 10:09 am
No, don't wait for the light to stop pulsing. That indicates that the bootloader is running. The upload MUST begin while the LED is pulsing.
by franklin97355 on Fri Oct 28, 2016 3:54 pm
Also remember that when you press the upload button the compiler compiles before the uploader can start. You want to make sure the light is flashing while the UPLOADER is trying to upload.
franklin97355
by montreuilg on Fri Nov 04, 2016 3:19 pm
adafruit_support_rick wrote:Please email support@adafruit.com with a link to this thread for a replacement
Everything is working fine now, thank you very much Rick and AdaTeam!
montreuilg
by adafruit_support_rick on Sat Nov 05, 2016 7:31 am
Glad to hear it!
