🔮Adafruit sale all weekend long – use the code ADATHX for 15% off! 🔮
Errors uploading to Gemma v2
by brianlay on Tue Oct 25, 2016 12:50 pm
Running Arduino IDE 1.6.12 on MAC OS Sierra 10.12
Mac system Prefences reports Trinket connected
Previously uploaded to Flora with no problem
The IDE does not have a /dev/cu.isbmodem26421 to select as a port when I choose Gemma or Trinket as a board.
Errors reported during upload:
Arduino: 1.6.12 (Mac OS X), Board: "Adafruit Trinket 8MHz"
Sketch uses 2,432 bytes (45%) of program storage space. Maximum is 5,310 bytes.
Global variables use 39 bytes of dynamic memory.
/Applications/Arduino 2.app/Contents/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino 2.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf -v -pattiny85 -cstk500v2 -Pusb -Uflash:w:/var/folders/t9/qdmscc850b14_qfmpy40bj800000gq/T/arduino_build_860846/unicorn_horn.ino.hex:i
avrdude: Version 6.3, compiled on Sep 12 2016 at 17:22:25
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "/Applications/Arduino 2.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf"
         User configuration file is "/Users/brianlay/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : usb
         Using Programmer              : stk500v2
avrdude: usbdev_open(): did not find any USB device "usb" (0x03eb:0x2104)
avrdude done.  Thank you.
An error occurred while uploading the sketch
Ok, I figured this out. The IDE will never show a port to connect to.
Just upload the sketch while the bootloader red light is flashing and it works1
brianlay
