Gemma and Sequins
Gemma and Sequins
by slazear on Fri Nov 11, 2016 5:48 pm
I have a Gemma and am using sequins. There is no data port.
So, am I able to control how power reaches the sequins in order to have some creative effect with lighting? (fading in and out?)
A reference to code to do this if possible would be appreciated.
Susan
slazear
Re: Gemma and Sequins
by adafruit_support_jarek on Fri Nov 11, 2016 5:56 pm
Hi there! On the Gemma ( https://www.adafruit.com/product/1222 ) there are two PWM pins, D0 and D1. You can use those to control the brightness of any sequins attached to it by using the following functions:
analogWrite( 0, brightness );
analogWrite( 1, brightness );
where brightness is how bright you want the sequin to be.
by slazear on Fri Nov 11, 2016 9:14 pm
Hi
Sorry for my ignorance... Are those not data points? How do the sequins understand that with no date input connection?
I was hoping that the power (power and ground) could be controlled. Or does that code control the power? Im new to this.. Have a garment/bracelet going in a fashion show tomorrow night and was hoping to have it do more than just shine. But I'm using sequins not neo pixels.
Susan
slazear
by adafruit_support_jarek on Fri Nov 11, 2016 9:38 pm
You are correct, those are not data points. You can control the power and ground using the data pins on your Flora, check out this guide for an example: https://learn.adafruit.com/interior-pur ... t/overview
There is also example code in that guide showing some very basic functions for controlling the lights :)
