🔮Adafruit sale all weekend long – use the code ADATHX for 15% off! 🔮
Problem uploading to board
by Tyler85340 on Sun Feb 12, 2017 3:30 am
Using (2 different) Pro Trinket 5v (pin 6), Powerboost 500c (connected to Trinket through +/- on back), 30 LED strip/ 16 LED ring (Data Input). Battery powered using 22AWG cable and connected through Micro USB to USB Male A. Tried IDE 1.8.1, retro installed 1.6.5. USB Drivers installed, Pro Trinket Drivers installed, Board: Arduino Pro or Pro Mini (no option for USB or FTDI), Processor ATmega328 (5v 16MHz), Port: COM1, Programmer: USBtinyISP. I've tried Strandtest, simple, and blink.
Consistent Error:
"Sketch uses 3,816 bytes (12%) of program storage space. Maximum is 30,720 bytes.
Global variables use 40 bytes (1%) of dynamic memory, leaving 2,008 bytes for local variables. Maximum is 2,048 bytes.
avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xeb
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xeb
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xeb
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xeb
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xeb
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xeb
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xeb
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xeb
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xeb
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xeb
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
Bootloading LED is consistently pulsing during connection. I've been going through the forums for hours and I cant find the answer. First time Adafruit customer and I need some help, deadline is 2 weeks away and I need 7 circuits completed. Thanks in advance.
Tyler85340
Re: Problem uploading to board
by franklin97355 on Sun Feb 12, 2017 3:08 pm
That's not a Pro Trinket. Select the Pro Trinket 5V
franklin97355
by Tyler85340 on Sun Feb 12, 2017 3:22 pm
Thats not an option for a board and it doesnt come up when I search in board manager. Where can I get that?
Tyler85340
by franklin97355 on Sun Feb 12, 2017 4:37 pm
franklin97355
