Serial Error with ATTINY85?
by ArtofWar on Thu Mar 16, 2017 7:29 pm
I brought this Proximity Sensor from AdaFruit
https://github.com/adafruit/Adafruit_VCNL4010
..and got with working with the Uno R.3 with the example code that was provided. But when I try to run it on ATTINY85 I'm getting this error.
C:\Users\Terry\AppData\Local\Temp\arduino_modified_sketch_791563\ArduinoISP.ino: In function 'void loop()':
ArduinoISP:24: error: 'Serial' was not declared in this scope
Serial.print("Ambient: "); Serial.println(vcnl.readAmbient());
exit status 1
What do i need to do to get this to work. Thanks
ArtofWar
Re: Serial Error with ATTINY85?
by marke3 on Fri Mar 17, 2017 4:25 am
The Attiny85 doesn't have hardware serial so you will need to use a software serial library or an I2C display to replace the outputs using "serial.****" in the example sketch.
marke3
