New USBTinyISP, won't connect: "Device Descriptor Request Fa
by rspoering on Tue May 09, 2017 9:36 pm
Hi Adafruit,
I just received my USBTinyISP kit today and built it up, but had a total fail plugging it in. I've attached the error message: "The last USB device you connected to this computer malfunctioned..." upon plugging it in. Device manager has it under unknown devices with the error "Device Descriptor Request Failed."
I tried this on a Surface Pro 4 (USB 3.0), a desktop PC (USB 2 and 3) and a Mac (USB 2). All of them see it as a broken device.
I get no LED. I tried the following:
- went back over all solder joints, double checked all components, did continuity and voltage spot checks, all seems ok. The board is powered. Photos attached of both sides:
- I probed the resonator with my oscilloscope but got no signal (inconclusive according to searches).
- tried multiple USB cables.
- tried manually installing drivers, from both "usbtiny_signed_8" and "adafruit_drivers" installers.
- searched the forums and Google to the best of my ability without finding other solutions.
Any ideas?
Many thanks for your assistance.
rspoering
Re: New USBTinyISP, won't connect: "Device Descriptor Reques
by adafruit_support_rick on Wed May 10, 2017 12:33 pm
Well, the build looks good. Possibly, you got an unprogrammed processor chip.
Please email support@adafruit.com with a link to this post and ask them for a USBtinyISP processor chip:
https://www.adafruit.com/product/54
by rspoering on Wed May 10, 2017 8:28 pm
Thanks, will do!
rspoering
by rspoering on Sat May 13, 2017 9:19 pm
Hi everyone,
Huge thanks to Adafruit, amazing service! They sent me out a new kit right away.
Unfortunately the new chip didn't work in the first board, and when I built up the new board it still gave the same errors, with either chip, on both of my machines.
I figured maybe Windows 10 was causing problems so I tried more extreme measures to get the drivers installed, including trying to write the drivers with Zadig. It seems clear that the device is not giving the computer the basic hello that it needs to be recognized (device descriptor request failed.)
I can't believe that I built the board wrong twice, or that I was sent bad chips twice. What options remain?
Thanks.
rspoering
by adafruit_support_rick on Sun May 14, 2017 10:10 am
No green light means that there was no USB enumeration. Which is what you're seeing.
Two bad programmers is not likely, and your build on the first one looks good. You've tried different computers. That leaves the cables you're using. Or possibly it's some USB3.0 issue.
Can you try going through a USB2.0 hub?
by rspoering on Mon May 15, 2017 9:26 am
I have tried 3 different USB cables and a USB 2.0 hub. The only difference with the hub is that it reports Unknown USB Device (Port Reset Failed) instead of (Device Descriptor Request Failed). Still no green light.
rspoering
by adafruit2 on Mon May 15, 2017 5:55 pm
we don't know whats up but you probably just have systems that don't like bitbanged USB :) you can email support@adafruit for a refund but we don't recommend getting another kit...
adafruit2
Site Admin
