I buy a trinket 5V, and i installed Arduino IDE 1.8. I following the instructions the link: https://learn.adafruit.com/introducing- ... dows-setup, but I have a problem when i upload the code at trinket. I have the following messages:
Arduino: 1.8.3 (Windows 7), Board: "Adafruit Trinket 8MHz"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\opdei\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\opdei\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\opdei\Documents\Arduino\libraries -fqbn=adafruit:avr:trinket3 -ide-version=10803 -build-path C:\Users\opdei\AppData\Local\Temp\arduino_build_297219 -warnings=none -build-cache C:\Users\opdei\AppData\Local\Temp\arduino_cache_565431 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\opdei\Documents\Arduino\ejemplo3\ejemplo3.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\opdei\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\opdei\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\opdei\Documents\Arduino\libraries -fqbn=adafruit:avr:trinket3 -ide-version=10803 -build-path C:\Users\opdei\AppData\Local\Temp\arduino_build_297219 -warnings=none -build-cache C:\Users\opdei\AppData\Local\Temp\arduino_cache_565431 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\opdei\Documents\Arduino\ejemplo3\ejemplo3.ino
Using board 'trinket3' from platform in folder: C:\Users\opdei\AppData\Local\Arduino15\packages\adafruit\hardware\avr\1.4.9
Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Detecting libraries used...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=attiny85 -DF_CPU=8000000L -DARDUINO=10803 -DARDUINO_AVR_TRINKET3 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Users\opdei\AppData\Local\Arduino15\packages\adafruit\hardware\avr\1.4.9\variants\tiny8" "C:\Users\opdei\AppData\Local\Temp\arduino_build_297219\sketch\ejemplo3.ino.cpp" -o "nul"
Generating function prototypes...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=attiny85 -DF_CPU=8000000L -DARDUINO=10803 -DARDUINO_AVR_TRINKET3 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Users\opdei\AppData\Local\Arduino15\packages\adafruit\hardware\avr\1.4.9\variants\tiny8" "C:\Users\opdei\AppData\Local\Temp\arduino_build_297219\sketch\ejemplo3.ino.cpp" -o "C:\Users\opdei\AppData\Local\Temp\arduino_build_297219\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\opdei\AppData\Local\Temp\arduino_build_297219\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=attiny85 -DF_CPU=8000000L -DARDUINO=10803 -DARDUINO_AVR_TRINKET3 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Users\opdei\AppData\Local\Arduino15\packages\adafruit\hardware\avr\1.4.9\variants\tiny8" "C:\Users\opdei\AppData\Local\Temp\arduino_build_297219\sketch\ejemplo3.ino.cpp" -o "C:\Users\opdei\AppData\Local\Temp\arduino_build_297219\sketch\ejemplo3.ino.cpp.o"
Compiling libraries...
Compiling core...
Using precompiled core
Linking everything together...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=attiny85 -o "C:\Users\opdei\AppData\Local\Temp\arduino_build_297219/ejemplo3.ino.elf" "C:\Users\opdei\AppData\Local\Temp\arduino_build_297219\sketch\ejemplo3.ino.cpp.o" "C:\Users\opdei\AppData\Local\Temp\arduino_build_297219/..\arduino_cache_565431\core\core_adafruit_avr_trinket3_0c812875ac70eb4a9b385d8fb077f54c.a" "-LC:\Users\opdei\AppData\Local\Temp\arduino_build_297219" -lm
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\Users\opdei\AppData\Local\Temp\arduino_build_297219/ejemplo3.ino.elf" "C:\Users\opdei\AppData\Local\Temp\arduino_build_297219/ejemplo3.ino.eep"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-objcopy" -O ihex -R .eeprom "C:\Users\opdei\AppData\Local\Temp\arduino_build_297219/ejemplo3.ino.elf" "C:\Users\opdei\AppData\Local\Temp\arduino_build_297219/ejemplo3.ino.hex"
Sketch uses 660 bytes (12%) of program storage space. Maximum is 5310 bytes.
Global variables use 9 bytes of dynamic memory.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -pattiny85 -cusbtiny -Uflash:w:C:\Users\opdei\AppData\Local\Temp\arduino_build_297219/ejemplo3.ino.hex:i
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
An error occurred while uploading the sketch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : usb
Using Programmer : usbtiny
avrdude: usbdev_open(): Found USBtinyISP, bus:device: bus-0:\\.\libusb0-0001--0x1781-0x0c9f
AVR Part : ATtiny85
Chip Erase delay : 400000 us
PAGEL : P00
BS2 : P00
RESET disposition : possible i/o
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 12 4 0 no 512 4 0 4000 4500 0xff 0xff
flash 65 6 32 0 yes 8192 64 128 30000 30000 0xff 0xff
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
Programmer Type : USBtiny
Description : USBtiny simple USB programmer, http://www.ladyada.net/make/usbtinyisp/
avrdude: programmer operation not supported
avrdude: Using SCK period of 10 usec
avrdude: error: usbtiny_transmit:
this check.
avrdude done. Thank you.
Thanks for help me.
Problem with upload code with Arduino IDE over TRINKET
- OswaldoP
