Trinket pro 5v upload problems
by jackieh111 on Mon Jun 12, 2017 4:58 pm
Hi
I'm working on the BIke POV. I've uploaded and ran the strand test fine but when I try to upload bikewheel.ino I get the text below - basically broken pipe mismatch error. I do get a broken pipe eroor when I load the strand test occasionally but if I retry I usually get a clean upload. I never get a clean upload with bikewheel. I'm using a mac with a USB2 hub connected, I've tried with zero success other micro usbs and tried an older mac that is USB2 only. Any other ideas?
Arduino: 1.8.1 (Mac OS X), Board: "Pro Trinket 5V/16MHz (USB)"
Sketch uses 26772 bytes (93%) of program storage space. Maximum is 28672 bytes.
Global variables use 102 bytes of dynamic memory.
/Users/jacqh/Dev_apps/Arduino.app/Contents/Java/hardware/tools/avr/bin/avrdude -C/Users/jacqh/Dev_apps/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -cusbtiny -Uflash:w:/var/folders/yx/sl6g43zx15j69nlqclz2blhw0000gn/T/arduino_build_588940/myBikewheel.ino.hex:i
avrdude: Version 6.3, compiled on Dec 16 2016 at 13:32:25
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/Users/jacqh/Dev_apps/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/Users/jacqh/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : usb
Using Programmer : usbtiny
avrdude: usbdev_open(): Found USBtinyISP, bus:device: 029:008
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : USBtiny
Description : USBtiny simple USB programmer, http://www.ladyada.net/make/usbtinyisp/
avrdude: programmer operation not supported
avrdude: Using SCK period of 10 usec
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "/var/folders/yx/sl6g43zx15j69nlqclz2blhw0000gn/T/arduino_build_588940/myBikewheel.ino.hex"
avrdude: writing flash (26772 bytes):
Writing | #
avrdude: error: usbtiny_send: Broken pipe (expected 128, got -32)
avrdude: 4 retries during SPI command
################################################# | 100% 21.36s
avrdude: 26772 bytes of flash written
avrdude: verifying flash memory against /var/folders/yx/sl6g43zx15j69nlqclz2blhw0000gn/T/arduino_build_588940/myBikewheel.ino.hex:
avrdude: load data flash data from input file /var/folders/yx/sl6g43zx15j69nlqclz2blhw0000gn/T/arduino_build_588940/myBikewheel.ino.hex:
avrdude: input file /var/folders/yx/sl6g43zx15j69nlqclz2blhw0000gn/T/arduino_build_588940/myBikewheel.ino.hex contains 26772 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 1.78s
avrdude: verifying ...
avrdude: verification error, first mismatch at byte 0x0084
0xc1 != 0xff
avrdude: verification error; content mismatch
avrdude done. Thank you.
the selected serial port
does not exist or your board is not connected
jackieh111
Re: Trinket pro 5v upload problems
by jackieh111 on Mon Jun 12, 2017 10:35 pm
I've tried this on a windows 10 machine, again using usb 2 hub and got thsi result:
Arduino: 1.8.3 (Windows 10), Board: "Pro Trinket 5V/16MHz (USB)"
Sketch uses 26776 bytes (93%) of program storage space. Maximum is 28672 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -cusbtiny -Uflash:w:C:\Users\RESCO_~1\AppData\Local\Temp\arduino_build_589622/bikewheel.ino.hex:i
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : usb
avrdude: usbdev_open(): Found USBtinyISP, bus:device: bus-0:\\.\libusb0-0001--0x1781-0x0c9f
PAGEL : PD7
BS2 : PC2
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
avrdude: reading input file "C:\Users\RESCO_~1\AppData\Local\Temp\arduino_build_589622/bikewheel.ino.hex"
avrdude: writing flash (26776 bytes):
Writing |
avrdude: error: usbtiny_send: (expected 128, got -5)
################################################## | 100% 19.92s
avrdude: 26776 bytes of flash written
avrdude: verifying flash memory against C:\Users\RESCO_~1\AppData\Local\Temp\arduino_build_589622/bikewheel.ino.hex:
avrdude: load data flash data from input file C:\Users\RESCO_~1\AppData\Local\Temp\arduino_build_589622/bikewheel.ino.hex:
avrdude: input file C:\Users\RESCO_~1\AppData\Local\Temp\arduino_build_589622/bikewheel.ino.hex contains 26776 bytes
Reading | #############################################the selected serial port ##### does not exist or your board is not connected
##### | 100% 1.26s
avrdude: verification error, first mismatch at byte 0x00e4
0x3b != 0xff
jackieh111
by jackieh111 on Tue Jun 13, 2017 11:09 am
so I tested loading Bikewheel on two other 5v Trinket Pro - and it worked with no issues on one even using the USB3 hub on my mac without a hub. So it seems that two of my trinkets out of three have issues. Can I return them to get new ones?
jackieh111
