Black Lives Matter - Action and Equality.
Programming the Trinket
by Thrivenrg on Wed Sep 13, 2017 12:54 pm
Ok I bought a bunch of these little guys to perform all sorts of stuff for my companies development. Creating little timer modules is the biggest job we want them for as time functions hold thing up in core software.
So now I have timer code set up and ready to go. But now I cant figure out how to program this little guy. So here is where Im at.
Plugged the Trinket in to the pc, driver has loaded fine.
Ive gone in and selected USBtinyISP from the programmer in the tools menu.
Under Boards in the tools Menu, I have " Arduino Gemma" selected
In the Tools Menu "port" is grayed out. Question: Is there supposed to be a port available using this configuration?
Before I upload I press the button on the board and it goes dim initially and then pulses afterward.
So with no port selected as there is not an option available; Ive tried to upload and I get an error.
"avrdude: Error: Could not find USBtiny device (0x1781/0xc9f)"
I am running an older version of the Arduino IDE I think; its version 1.6.7
My PC is running window 8.1 and does not have USB 3.0 ports they are 2.0 versions.
My code:
int InputPin = analogRead(0);    // select the input pin for the potentiometer
int OutputPin = 3;      // select the pin for the LED
int sensorValue=0;  // variable to store the value coming from the sensor
int InputState = 0;
void setup()
  // declare the ledPin as an OUTPUT:
  pinMode(OutputPin, OUTPUT);
  pinMode(InputPin, INPUT);
void timer1(){
  InputState = digitalRead(InputPin);
        int timer1_value = (50);
        for (int i = timer1_value; i >= 0; i--){ //Begin the loop
            delay(100);
void timer2(){
        int timer2_value = (1);
        for (int i = timer2_value; i >= 0; i--){ //Begin the loop
            delay(100);
    if (InputState == HIGH){
  digitalWrite(OutputPin, LOW);
 timer1();
  digitalWrite(OutputPin, HIGH);
timer2();
else{
Thrivenrg
Re: Programming the Trinket
by franklin97355 on Wed Sep 13, 2017 1:22 pm
Select the Trinket in the boards menu. The instructions are in the tutorial.
franklin97355
franklin97355
by Thrivenrg on Wed Sep 13, 2017 1:27 pm
There is not an option for that
Thrivenrg
by Thrivenrg on Wed Sep 13, 2017 1:31 pm
franklin97355 wrote:Select the Trinket in the boards menu. The instructions are in the tutorial.
This is not a tutorial its the description page to purchase this.
Edit: its the introduction page it does not have instruction to upload from the Arduino IDE.
Thrivenrg
by Thrivenrg on Wed Sep 13, 2017 1:58 pm
Here is the screen shot of the IDE and board selection.
Arduino IDE Trinket 1.png (108.38 KiB) Viewed 1574 times
Thrivenrg
by franklin97355 on Wed Sep 13, 2017 2:14 pm
Did you look at these sections?
franklin97355
by Thrivenrg on Wed Sep 13, 2017 2:38 pm
Ok Ive found the links and following instructions now. I have the baords loaded up and now working on loading the adafruit windows drivers. Ill post results here is a few, I really want this guy to work!
Cheers
Thrivenrg
by Thrivenrg on Wed Sep 13, 2017 2:44 pm
Ok it worked, thank you for your assistance! If I run into any more walls Ill be back haha.
Cheers
Thrivenrg
by franklin97355 on Wed Sep 13, 2017 4:27 pm
Glad I could be of assistance.
franklin97355
by Al_GM on Fri Dec 29, 2017 10:17 pm
i have the same problem i have tried with windows and Raspian, download adafruits drivers and when connect the trinket is recognized in control panel>printer and devices like trinket, but the same in ports there is only COM1 and the problem is the error "Could not find USBtiny device (0x1781/0xc9f)" i have done all in the different adafruit pages but nothing even i tried with diferent cables, a new one, without success. help
Al_GM
by franklin97355 on Fri Dec 29, 2017 10:47 pm
How are you setting up the IDE for uploads?
franklin97355
