The green LED on the Trinket means it sees your computer. Lack of TRINKETBOOT showing up on your computer means your computer is not seeing the Trinket. Did you install the drivers?
https://learn.adafruit.com/adafruit-tri ... stallation
Trinket M0: Could not find USBtiny device
- adafruit_support_carter
- PrefontDon
Re: Trinket M0: Could not find USBtiny device
Yes, I have installed the drivers as per your link. Here's a screenshot of my searching for TRINKETBOOT.
- Attachments
- No Trinkboot Folder.jpg (29.07 KiB) Viewed 1130 times
Hmmm. Can you post a screen shot of your file explorer window with the Trinket in bootloader mode. Like this:
https://learn.adafruit.com/assets/41271
and also what your device manager shows.
- PrefontDon
Here you go.
- Attachments
- TrinketM0.zip
- (499.34 KiB) Downloaded 111 times
- PrefontDon
When I attach the Trinket's USB cable to an unused USB hub port, the CIRCUITPY drive is recognized as E:. When I press the Reset button quickly twice to force Bootloader mode, the aforementioned Python drive disappears.
I have two Trinket M0s that display the same behavior.
- adafruit2
you have the older driver, which sometimes caused this. GOOD NEWS we have a solution
you need to compelel UNINSTALL and DELETE the old driver
https://learn.adafruit.com/adafruit-tri ... -faq#faq-1
then installed the 2.0.0 driver
- PrefontDon
Success!
Thanks very much!
Thanks very much!
- Attachments
- 2017-10-02_07.jpg (267.33 KiB) Viewed 1096 times
- adafruit2
- PrefontDon
- curious1
I am trying to get the correct software version and board add-ons to get a Trinket to work with a windows 7 computer.
