Black Lives Matter - Action and Equality.
Trinket M0: Could not find USBtiny device
Re: Trinket M0: Could not find USBtiny device
by adafruit_support_carter on Mon Oct 02, 2017 10:02 am
The green LED on the Trinket means it sees your computer. Lack of TRINKETBOOT showing up on your computer means your computer is not seeing the Trinket. Did you install the drivers?
https://learn.adafruit.com/adafruit-tri ... stallation
by PrefontDon on Mon Oct 02, 2017 10:08 am
Yes, I have installed the drivers as per your link. Here's a screenshot of my searching for TRINKETBOOT.
No Trinkboot Folder.jpg (29.07 KiB) Viewed 863 times
PrefontDon
by adafruit_support_carter on Mon Oct 02, 2017 10:21 am
Hmmm. Can you post a screen shot of your file explorer window with the Trinket in bootloader mode. Like this:
https://learn.adafruit.com/assets/41271
and also what your device manager shows.
by PrefontDon on Mon Oct 02, 2017 10:52 am
Here you go.
TrinketM0.zip
(499.34 KiB) Downloaded 93 times
PrefontDon
by PrefontDon on Mon Oct 02, 2017 10:57 am
When I attach the Trinket's USB cable to an unused USB hub port, the CIRCUITPY drive is recognized as E:. When I press the Reset button quickly twice to force Bootloader mode, the aforementioned Python drive disappears.
I have two Trinket M0s that display the same behavior.
PrefontDon
by adafruit2 on Mon Oct 02, 2017 11:35 am
you have the older driver, which sometimes caused this. GOOD NEWS we have a solution
you need to compelel UNINSTALL and DELETE the old driver
https://learn.adafruit.com/adafruit-tri ... -faq#faq-1
then installed the 2.0.0 driver
adafruit2
Site Admin
by PrefontDon on Mon Oct 02, 2017 1:22 pm
Success!
Thanks very much!
PrefontDon
by adafruit2 on Mon Oct 02, 2017 1:24 pm
huzzah!
adafruit2
Site Admin
by PrefontDon on Mon Oct 02, 2017 1:27 pm
PrefontDon
by curious1 on Wed Feb 28, 2018 12:39 pm
I am trying to get the correct software version and board add-ons to get a Trinket to work with a windows 7 computer.
curious1
by adafruit_support_carter on Wed Feb 28, 2018 1:02 pm
@curious1 Please start a new thread for your question. Also, please clarify if you are working with the older Trinket (PID 1501) or the newer Trinket M0 (PID 3500).
