Trinket Time Lapse Camera Programming Issues
by jpcarnes on Mon Nov 06, 2017 10:52 pm
I am building the time lapse camera using the trinket that was posted on the adafruit website (link below):
https://learn.adafruit.com/portable-min ... a/overview
I have bought everything and assembled the circuit. The switch works and everything turns on. I am using a windows desktop to program the trinket. I plug the trinket in and get the red flashing light to upload code and upload the code provided on the website for the time lapse camera, but then when I do that i get the error "avrdude: error: usbtiny_receive: (expected 4, got -5)". I checked all pin connections and solder joints and to my knowledge they seem to be ok. When programming the trinket I am selecting the board as Adafruit Trinket 16 MHz and the programmer as USBtinyISP. Not sure where to even start trouble shooting to fix this issue, any help is greatly appreciated, thanks!
jpcarnes
Re: Trinket Time Lapse Camera Programming Issues
by adafruit_support_carter on Tue Nov 07, 2017 12:09 pm
Post a photo of your setup showing all connections. Also post the full output from the Arduino IDE when you try and do the build / upload of the sketch.
by jpcarnes on Fri Nov 10, 2017 11:10 pm
Attached are in depth photos of the circuit and also pictures of the run time error and board info. I have basic soldering skills so I am not sure if I have cold joints or not. Sorry for the late response, and thanks in advance for the help, finishing this will help me out big time on a project I am working on for school! The code from the adafruit was used to test and wasn't changed.
jpcarnes
by jpcarnes on Fri Nov 10, 2017 11:11 pm
Here are the rest of the pictures:
jpcarnes
by adafruit_support_carter on Mon Nov 13, 2017 1:05 pm
Try disconnecting the battery from the LiPoly board and see if you can get the basic blink sketch to work on the Trinket:
https://learn.adafruit.com/introducing- ... -ide#blink
