Black Lives Matter - Action and Equality.
Gemma V2 (black) won't run any code
by bostrovsky on Wed Oct 17, 2018 6:23 pm
For example...this is what I get when I just try to run the blink code:
Arduino: 1.8.6 (Mac OS X), Board: "Adafruit Gemma (ATtiny85 @ 8MHz)"
Build options changed, rebuilding all
/Applications/Arduino1.6.app/Contents/Java/hardware/arduino/avr/cores/arduino/WInterrupts.c: In function 'attachInterrupt':
/Applications/Arduino1.6.app/Contents/Java/hardware/arduino/avr/cores/arduino/WInterrupts.c:166:8: warning: #warning attachInterrupt may need some more work for this cpu (case 1) [-Wcpp]
/Applications/Arduino1.6.app/Contents/Java/hardware/arduino/avr/cores/arduino/WInterrupts.c: In function 'detachInterrupt':
/Applications/Arduino1.6.app/Contents/Java/hardware/arduino/avr/cores/arduino/WInterrupts.c:255:8: warning: #warning detachInterrupt may need some more work for this cpu (case 1) [-Wcpp]
In file included from /Applications/Arduino1.6.app/Contents/Java/hardware/arduino/avr/cores/arduino/WInterrupts.c:29:0:
/Applications/Arduino1.6.app/Contents/Java/hardware/arduino/avr/cores/arduino/WInterrupts.c: In function 'INT1_vect':
/Applications/Arduino1.6.app/Contents/Java/hardware/arduino/avr/cores/arduino/WInterrupts.c:310:15: warning: 'INT1_vect' appears to be a misspelled signal handler, missing __vector prefix [-Wmisspelled-isr]
IMPLEMENT_ISR(INT1_vect, EXTERNAL_INT_1)
/Applications/Arduino1.6.app/Contents/Java/hardware/arduino/avr/cores/arduino/WInterrupts.c:310:1: note: in expansion of macro 'IMPLEMENT_ISR'
In file included from /Applications/Arduino1.6.app/Contents/Java/hardware/arduino/avr/cores/arduino/Tone.cpp:37:0:
/Applications/Arduino1.6.app/Contents/Java/hardware/arduino/avr/cores/arduino/Tone.cpp: In function 'void TIMER2_COMPA_vect()':
/Applications/Arduino1.6.app/Contents/Java/hardware/arduino/avr/cores/arduino/Tone.cpp:538:5: warning: 'TIMER2_COMPA_vect' appears to be a misspelled signal handler, missing __vector prefix [-Wmisspelled-isr]
ISR(TIMER2_COMPA_vect)
Sketch uses 700 bytes (13%) of program storage space. Maximum is 5310 bytes.
Global variables use 9 bytes of dynamic memory.
avrdude: error: usbtiny_transmit: Broken pipe
this check.
I am running v. 1.8.6 of the arduino IDE with Adafruit Gemma chosen as the board and USBtinyISP selected and this cable works perfectly with other Arduino and feather devices.
bostrovsky
