Error could not find USBtiny device (0x178/0xc9f)
by bdodds on Tue Aug 20, 2019 12:38 pm
I'm using the kit from here I got a few years ago.
Mac OS 10.14.6 on a MacBook Pro with AVRDUDE in the terminal.
The USBtinyISP was working just fine till today when I started getting the Error could not find USBtiny device (0x178/0xc9f)
The green light comes on and I can see the device listed in the system report for connected USB devices...
I have used it hundreds of times on this same laptop without issue. How would I test to see if the device is indeed still working?
Screen Shot 2019-08-20 at 9.27.55 AM.png (91.86 KiB) Viewed 505 times
bdodds
Re: Error could not find USBtiny device (0x178/0xc9f)
by bdodds on Thu Aug 22, 2019 12:09 pm
No one has any ideas? Is anyone else using the USBTiny on MacOS 10.14.6 successfully?
bdodds
by protodome on Tue Sep 17, 2019 11:25 am
Just signed up to say that I'm having exactly the same issue. Everything was working fine until a few days ago, now avrdude inexplicably can't find the USBtiny device, despite it being listed in connected USB devices. Currently using a Macbook Pro 13" 2019 on 10.14.6.
protodome
by protodome on Tue Sep 17, 2019 9:09 pm
Okay, I solved it (at least for me). If you simply reinstall avrdude using Homebrew (then restart) it works. Perhaps a recent update broke something?
Hope this helps someone else!
protodome
by bdodds on Tue Sep 17, 2019 10:04 pm
I think I installed using Crosspack, can you provide a link about installing via Homebrew?
bdodds
by protodome on Tue Sep 17, 2019 10:20 pm
It's pretty simple. Follow the instructions here: https://brew.sh/
You'll need to copy the following into Terminal to install Homebrew:
/usr/bin/ruby -e "$(curl -fsSL https://raw.githubusercontent.com/Homebrew/install/master/install)"
Then, once it's done, you'll need to enter:
brew install avrdude
Restart your machine and you should be good!
protodome
by bdodds on Wed Sep 18, 2019 8:12 pm
Thanks I'm going to give this a try when I find a free moment.
bdodds
by bdodds on Mon Sep 23, 2019 9:57 pm
protodome, you rock.
I installed Homebrew and then had it install Avrdude again and it works now!
I'm guessing in the 10.14.6 update broke it because another mac running 10.14.5 still works.
bdodds
by PEAcademy on Fri Oct 04, 2019 11:54 am
protodome wrote:Okay, I solved it (at least for me). If you simply reinstall avrdude using Homebrew (then restart) it works. Perhaps a recent update broke something?
Thank you @protodome! It sure helped me. I had the exact same issue and reinstalling avrdude worked. It had been working just fine not long ago, but then I kept getting that error.
PEAcademy
