Trinket 5V and Adafruit TLC59711
by zophar on Thu Jul 02, 2020 1:40 pm
Hi All,
i'm trying to get the trinket 5V to work with Adafruit's 59711 PWM board. The issue seems to come through a number of things, I can fix the serial print info by using ATtinySerialOut. I have looked at using tinySPI: but not sure what else I need to modify. Is this even possible?
The original library is here: https://github.com/adafruit/Adafruit_TL ... master.zip
Some of the compile errors (presumably because it's trying to use hardware SPI) are:
../packages/arduino/hardware/avr/1.8.3/libraries/SPI/src/SPI.h:310:55: error: 'SPIE' was not declared in this scope
inline static void detachInterrupt() { SPCR &= ~_BV(SPIE); }
../packages/arduino/hardware/avr/1.8.3/libraries/SPI/src/SPI.h:322:17: note: previous declaration as 'SPIClass SPI'
extern SPIClass SPI;
../packages/arduino/hardware/avr/1.8.3/libraries/SPI/src/SPI.h:310:42: note: suggested alternative: 'EECR'
EECR
Error compiling for board Adafruit Trinket (ATtiny85 @ 8MHz).
Do you think I can substitute the functions that don't work or should I just sack it off and use a nano.
Sorry for what is probably a really stupid question: I tried looking for further info but my brain just went fuzzy and I figured someone might at least be able to point me in the right direction?
Thanks in advance and apologies.
zophar
Re: Trinket 5V and Adafruit TLC59711
by adafruit_support_bill on Thu Jul 02, 2020 1:59 pm
I'd probably opt for one of the Itsy Bitsy boards: https://www.adafruit.com/product/3677
The Arduino SPI library does not support the ATTiny85. The errors you see are because the library is referencing hardware SPI registers that do not exist on that processor.
TinySPI claims to support a subset of the SPI library functionality. We have not tested it with the TLC59711.
by zophar on Fri Jul 03, 2020 10:58 am
Thanks Bill,
That’s great advice: the itsy bitsy looks ace. I shall stop attempting to get the software SPI to work. It was frazzling my mind a little.
Cheers.
zophar
