problems with the downloadable patched version of avrdude
by uhclem on Sun Jul 08, 2007 6:09 pm
./configure and 'make && sudo make install' went successfully on my 32-bit gentoo box. Thankfully it chose /usr/local/bin and did not touch my existing avrdude which does work with my stk500.
The usbtiny lights up green when plugged into a usb port.
usb 2-2: new low speed USB device using uhci_hcd and address 2
usb 2-2: configuration #1 chosen from 1 choice
However, when I try a basic avrdude command to query the programmer, I get this:
[email protected] ~ $ /usr/local/bin/avrdude -vvvv
avrdude: Version 5.3.1, compiled on Jul  8 2007 at 17:51:55
         Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
         System wide configuration file is "/usr/local/etc/avrdude.conf"
avrdude: libusb access not available in this configuration
avrdude: error at /usr/local/etc/avrdude.conf:371: programmer type not specified
[email protected]0 ~ $ dmesg
Linux version 2.6.19-gentoo-r5 ([email protected]) (gcc version 4.1.1 (Gentoo 4.1.1-r3)) #6 SMP Wed Jul 4 14:03:14 EDT 2007
All sorts of usb devices work great on this system. Also, line 371 of the config file is just the end of the 'usbtiny' section.
I am very confused. I must be missing something very obvious here.
uhclem
by adafruit on Sun Jul 08, 2007 7:42 pm
argh i know what the problem is. so in the Makefile theres a -DHAVE_USB that should be set but its not. i cant quite figure out autoconf to make it add it in there maybe you know autoconf better. otherwise...
grep the source files i think its HAVE_USB or maybe its HAVEUSB
anyways
add a -DHAVE_USB or whatever to the compiler flags and a -lusb in the linker flags in the Makefile and try again. -dont- do a ./configure again
hopefully i can get this ubuntu box up and then ill be able to make a distribution for it. :-S
Fixed in Makefile
by uhclem on Sun Jul 08, 2007 10:06 pm
Thank you very much for your reply. You were correct.
A 'cat *.c | grep -e USB turned up a bunch of 'HAVE_LIBUSB', so a quick trip to the Makefile to set CFLAGS like this:
CFLAGS = -g -O2 -DHAVE_LIBUSB
After a 'make clean', 'make' worked fine.
Now this:
/usr/local/bin/avrdude -v -c usbtiny -p 2313
Gives this:
avrdude: Version 5.3.1, compiled on Jul 8 2007 at 21:53:43
User configuration file is "/home/alex/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/parport0
Using Programmer : usbtiny
AVR Part : AT90S2313
Chip Erase delay : 20000 us
PAGEL : P00
BS2 : P00
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Success! There is a complaint later about timing but I recall seeing something about that elsewhere so no big deal.
Thanks again.
uhclem
by adafruit on Sun Jul 08, 2007 10:38 pm
sweet! can you maybe package up the binary and .conf file and send it to me: support-at-adafruit.com?
ill post it on the site
