Hex file USBtinyISP
Hex file USBtinyISP
by Mausman on Thu Aug 16, 2007 2:34 am
Could someone plz give me the hex file of the compiled firmware for the atmel?
I tried it several times with the makefile but none worked.
The hex file would be greatly apreciated.
Tia Mausman
Mausman
by Mausman on Thu Aug 16, 2007 2:06 pm
Ok, i want to program the 2313.
I have alot experiance with bascom and avrdude.
This is not the problem. The only thing is that i do not know how to compile the firmware.
I searched on the net for the compling instructions but i'm stuck.
Tia
Mausman
by adafruit on Thu Aug 16, 2007 2:09 pm
the code is in the spi directory. have you tried reading the Makefiles?
by Mausman on Thu Aug 16, 2007 3:46 pm
I tried but in this makefiles i am a compleet noob. :roll:
edit: with arvdude i directly flashed the hex and the fuses.
when i connect the board to a vista or xp pc it won't install.
Keeps saying unknown device.
Drivers for windows won't install and none of the leds lights up.
Mausman
by RUPARADOX on Tue Aug 21, 2007 7:39 pm
The HEX file in SPI directory is working fine, dont forget to program fuses for 12MHz work (WDR must be disabled,e.g. SET).
Thank's to LadyAda - SPASIBO!!!
RUPARADOX
