at90s2313 and at90s1200 comatibile?
by master_szumi on Fri Aug 17, 2007 3:24 pm
Can I program At90s2313 and At90s1200 via USBtinyISP?
Becouse i tried to program them and i have a problem - programmer dont see at90s1200 and "unable to read fuse properly" for at90s2313.
Could you write a list o compatibilty processors?
thx
James
master_szumi
by adafruit on Fri Aug 17, 2007 3:52 pm
it -should- work with any avr that AVRDUDE can program
but since the at90 chips you mentioned are discontinued and not available for purchase, i cant really test them! :?
I'll try to get a hold of these discontinued chips, tho...
the attiny2313 is pin-compatible, i think. does that work when you put it in?
by master_szumi on Fri Aug 17, 2007 4:51 pm
at90s2313 have already run when i added "-u" (unsafe mode in Avrdude) but at90s1200 still:
avrdude.exe: initialization failed, rc=-1
this check.
avrdude.exe done. Thank you.
master_szumi
by adafruit on Fri Aug 17, 2007 4:56 pm
theres a pretty good chance its just not wired up right or something. since you could program a different at90 chip it means that the usbtiny is OK and something else is incorrect
More info
by adrian650 on Sun Aug 19, 2007 6:06 pm
See my post in the 90s2313 thread...
adrian650
