External Interrupts on Trinket?
by ravewings on Wed Dec 04, 2013 10:11 am
I've been looking over the pinouts for the Trinket: http://learn.adafruit.com/introducing-trinket/pinouts ,but I'm not sure I understand it well enough. Are there any external interrupts on the Trinket microcontroller?
ravewings
Re: External Interrupts on Trinket?
by adafruit_support_bill on Wed Dec 04, 2013 10:36 am
PB2 on the chip is INT0 (among other things) the sole external interrupt on the ATTiny85. This is brought out as GPIO#2 on the Trinket.
by docwisdom on Tue Aug 05, 2014 1:47 am
Sorry to dig up an old thread, but can you do external interrupt and I2C on the Trinket at the same time?
docwisdom
by adafruit_support_rick on Tue Aug 05, 2014 6:19 am
docwisdom wrote:can you do external interrupt and I2C on the Trinket at the same time?
Sure! Just don't use the interrupt pin for I2C.
by lukebo on Sat Nov 11, 2017 12:33 pm
Hi everyone,
sorry to dig out that old thread again!
I did not really understand your answer, Rick. My problem is as follows. I want to use the trinket to grab the signal of an anemometer (10101010101 with a certain frequency) and measure that frequency. The result must be sent over I2C to a master for further processing. If i use GPIO2 to measure the frequency using the (only) interrupt, how can i use it as I2C clock line at the same time!?!? Can the clock line be changed? I always thought that it is fixed?
Thanks for the help,
Luke
lukebo
by adafruit_support_bill on Sat Nov 11, 2017 12:42 pm
The external interrupt would interfere with i2c. But you can use pin-change interrupts. Pin change interrupts (PCINTx) are supported on all of the GPIO pins.
by lukebo on Sat Nov 11, 2017 12:46 pm
Thanks a lot for the keywords, Bill!
lukebo
