ProTrinket Problems
ProTrinket Problems
by chasirish on Tue Sep 30, 2014 8:53 pm
Hi, I recently purchased a couple of ProTrinkets for use in my audio visualizer project. I'm having trouble uploading my code to the trinket though. I'm able to successfully upload the blink sketch, but when I try my code I get a couple of errors:
avrdude: error: usbtiny_transmit: usb_control_msg: sending control message failed, win error: A device attached to the system is not functioning.
this check.
Here is my code:
int analogPin = 1; // MSGEQ7 OUT
int strobePin = 12; // MSGEQ7 STROBE
int resetPin = 11; // MSGEQ7 RESET
int spectrumValue[7];
// MSGEQ7 OUT pin produces values around 50-80
// when there is no input, so use this value to
// filter out a lot of the chaff.
int filterValue = 80;
// LED pins. I used 2 common cathode RGB LEDs.
// They're connected to the PWM pins on the Arduino
int ledPinR1 = 3;
int ledPinG1 = 4;
int ledPinB1 = 5;
void setup()
  // Read from MSGEQ7 OUT
  pinMode(analogPin, INPUT);
  // Write to MSGEQ7 STROBE and RESET
  pinMode(strobePin, OUTPUT);
  pinMode(resetPin, OUTPUT);
  // Set analogPin's reference voltage
  analogReference(DEFAULT); // 5V
  // Set startup values for pins
  digitalWrite(resetPin, LOW);
  digitalWrite(strobePin, HIGH);
void loop()
  // Set reset pin low to enable strobe
  digitalWrite(resetPin, HIGH);
  // Get all 7 spectrum values from the MSGEQ7
  for (int i = 0; i < 7; i++)
    digitalWrite(strobePin, LOW);
    delayMicroseconds(30); // Allow output to settle
    spectrumValue[i] = analogRead(analogPin);
    // Constrain any value above 1023 or below filterValue
    spectrumValue[i] = constrain(spectrumValue[i], filterValue, 1023);
    // Remap the value to a number between 0 and 255
    spectrumValue[i] = map(spectrumValue[i], filterValue, 1023, 0, 255);
    // Remove serial stuff after debugging
//    Serial.print(spectrumValue[i]);
//    Serial.print(" ");
//   Serial.println();
   // Write the PWM values to the LEDs
   analogWrite(ledPinR1, spectrumValue[0]); // 63Hz
   analogWrite(ledPinR1, spectrumValue[1]); // 160Hz
   analogWrite(ledPinB1, spectrumValue[3]); // 1000Hz
   analogWrite(ledPinB1, spectrumValue[4]); // 2500Hz
   analogWrite(ledPinG1, spectrumValue[5]); // 6250Hz
   analogWrite(ledPinG1, spectrumValue[6]); // 16KHz
I've commented the serial lines out since the protrinket can't use it.
Please help if you can! Thank you!
Last edited by adafruit_support_rick on Wed Oct 01, 2014 9:54 am, edited 1 time in total.
Reason: please use Code tags when posting code (</> button)
chasirish
Re: ProTrinket Problems
by adafruit_support_rick on Wed Oct 01, 2014 9:56 am
That error indicates a bad connection between the computer and the Pro Trinket. Please try a different cable and a different USB port. also try connecting through a self-powered hub if possible.
by chasirish on Thu Oct 02, 2014 3:49 pm
adafruit_support_rick wrote:That error indicates a bad connection between the computer and the Pro Trinket. Please try a different cable and a different USB port. also try connecting through a self-powered hub if possible.
I tried switching the cord and also tried a different port. I still end up with the same errors. How come the blink code will work, but mine doesn't if that is the case.
Thanks for your help!
chasirish
by adafruit_support_rick on Thu Oct 02, 2014 3:55 pm
There's nothing about your code that will prevent an upload. Are you sure the blink example is uploading? Try changing the blink rate to verify that you're not just seeing a pre-loaded blink program.
by chasirish on Thu Oct 02, 2014 4:10 pm
adafruit_support_rick wrote:There's nothing about your code that will prevent an upload. Are you sure the blink example is uploading? Try changing the blink rate to verify that you're not just seeing a pre-loaded blink program.
You were right, it just showed the same error for that sketch as well
chasirish
by adafruit_support_rick on Thu Oct 02, 2014 4:34 pm
What do you have your Programmer set for in the Tools menu? It should be set to USBtinyISP
by chasirish on Thu Oct 02, 2014 4:51 pm
adafruit_support_rick wrote:What do you have your Programmer set for in the Tools menu? It should be set to USBtinyISP
It's set to USBtinyISP
chasirish
by adafruit_support_rick on Thu Oct 02, 2014 7:13 pm
Hmmm... Let's try replacing it
Please email support@adafruit.com with a link to this thread for a replacement Pro Trinket
by chasirish on Thu Oct 02, 2014 9:52 pm
adafruit_support_rick wrote:Hmmm... Let's try replacing it
Well I bought 3, and I just tested it on the other 2. Same problem. I'm going to try a different computer next
chasirish
by chasirish on Fri Oct 03, 2014 1:35 pm
I get the same problem on the other computer as well
chasirish
by adafruit_support_rick on Fri Oct 03, 2014 4:31 pm
What do you see in Device Manager? How does the Pro Trinket appear?
When the bootloader is running (red LED is pulsing), it should appear under LibUSB-Win32 Devices as a "USBtinyISP AVR Programmer"
by chasirish on Fri Oct 03, 2014 4:34 pm
adafruit_support_rick wrote:What do you see in Device Manager? How does the Pro Trinket appear?
It appears as usbtiny
chasirish
by adafruit_support_rick on Fri Oct 03, 2014 4:50 pm
I'm stumped. You've got the driver installed, and the system is communicating with the Pro Trinket. So I don't understand why you're getting errors from avrdude.
I'll see if somebody else has an idea...
by chasirish on Fri Oct 03, 2014 5:02 pm
adafruit_support_rick wrote:I'm stumped. You've got the driver installed, and the system is communicating with the Pro Trinket. So I don't understand why you're getting errors from avrdude.
Thanks! I appreciate the help even if we can't find an answer
chasirish
by Virgil_Machine on Wed Oct 08, 2014 5:24 pm
I have the same problem, same message. 3V Pro Trinket delivered yesterday.
After fussing with the IDE mods, changing the board and programmer, and installing the driver, I got it to upload once: blink works.
After that I soldered the headers and came back to try again and get the message. Windows also barked at me a couple of times about unsupported device or device failing, but it's showing USBTiny in device manager as working now.
I uninstalled the driver and attempted to reinstall--it said there was an error in the driver. I deleted the driver, unzipped it again, and reinstalled. After a few tries it reinstalled ("device cannot start code(10"). I went to upload blink--same message. I pressed the reset button--it worked. Then I tried to upload one of my sketches, same message. Back to blink, same message.
I downloaded the driver again and tried to install that. Now I'm getting the "device cannot start" message consistently.
Next I rebooted (becuse it's Windows). Windows barked a few times and also refused to install the driver a few times as above, but it finally installled. However, I'm still getting the avrdude message.
Also, sometimes, but not every time, when I press the reset button to initialize the bootloader, the device is no longer recognized, and I have to disconnect and reconnect the USB cable a few times to get it back.
Meanwhile, my 3V Pro Trinket is happily running blink from the times I was able to upload.
Any ideas?.
Last edited by Virgil_Machine on Wed Oct 08, 2014 5:30 pm, edited 1 time in total.
Virgil_Machine
